Tom's Hardware > Forum > CPU & Components > CPUs > Athlon64 Spanks P4 in 90nm Power Consumption tests
Forum CPU & Components : CPUs - Athlon64 Spanks P4 in 90nm Power Consumption tests
Archived from groups: alt.comp.hardware.overclocking.amd,alt.comp.hardware.overclocking,comp.sys.ibm.pc.hardware.chips (More info?)
http://techreport.com/ja.zz?comments=7417
rms
Sponsored Links
hence the reason why Intel are going to go back to the old P3 design
soon.......
From Adam Webb, Overlag
"rms" <rsquires@flashREMOVE.net> wrote in message
news:B8e8d.3587$5b1.2113@newssvr17.news.prodigy.com...
> rms
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.772 / Virus Database: 519 - Release Date: 01/10/2004
Reply to Anonymous
On Tue, 5 Oct 2004 11:00:50 +0100, "Adam Webb"
>soon.......
Which they're going to have to do an AMD64 for... all over again. The
troubles with Dothan would perhaps indicate that they also have some more
work to do on their process.
Rgds, George Macdonald
"Just because they're paranoid doesn't mean you're not psychotic" - Who, me??
Reply to Anonymous
> rms
The results sound awful. I wonder what they actually used to measure the
wattage?
Reply to Anonymous
They've amended the results. Not as good as thought. Gets hotter this time.
http://www.sudhian.com/showdocs.cfm?aid=610
Ed Light
Smiley :-/
MS Smiley :-\
Send spam to the FTC at
uce@ftc.gov
Thanks, robots.
Reply to Anonymous
On Wed, 6 Oct 2004 09:41:44 -0700, "Ed Light" <nobody@nobody.there>
Hmm.. an overclocked processor runs hotter than one that is not
overclocked...
And they are surprised by the results?!?!
The wonders will never cease..
Tony Hill
hilla <underscore> 20 <at> yahoo <dot> ca
Reply to Anonymous
Nadeem wrote:
>> rms
> the wattage?
Presumably one of the many household-appliance-power-meter things. There's a
difference between running hot and being power hungry. The Prescott is both
(ie: runs hotter and uses more power than the Northwood), but judging from
these results the 90nm A64's are less power-hungry than the 130nm parts. The
jury appears to still be out on whether it runs hotter or not.
What really needs to be done is for someone (TectReport would be good, since
they already have a 90nm 3500+) to test the chips at a large range of
frequencies and plot the results. If the results look like (view with fixed
width font):
Power
usage
| 130nm **** ++
| 90nm
Speed
Then clearly AMD is going to be having the same problem as Intel scaling the
CPUs to higher speeds. Intel's additional problem was that the Prescott
started out being more power hungy even at the far left hand side of the
graph. AMD doesn't have this problem, so may be able to ramp better than
Intel has with the Prescott. The key thing to look at is if the power usage
for 90nm parts ever gets above that of 130nm parts. We now know that at
lower speeds, 90nm parts consume less power. So, if they ever get to the
point of crossing the 130nm part line (as shown in the ascii graph), then
it's fairly likely that they're going to hit the wall quicker than the
130's.
Michael Brown
www.emboss.co.nz : OOS/RSI software and more :)
Add michael@ to emboss.co.nz - My inbox is always open
Reply to Anonymous
Tony Hill <hilla_nospam_20@yahoo.ca> writes:
And the second article is only about CPU temperature, not
power consumption.
Usual braindead journalist stuff...
Reply to Anonymous
- 0 +
"Michael Brown" <see@signature.below> wrote in message
news:Zu49d.10657$JQ4.704492@news.xtra.co.nz...
> Nadeem wrote:
> >> rms
> > the wattage?
a
both
The
since
fixed
> width font):
> Power
> usage
> | 130nm **** ++
> | 90nm
> Speed
Power consumption of CMOS is _proportional_ to core frequency.
Therefore the chart is likely to be something like this:
Power
| 90nm +**
| 130nm
0 Speed
Regards
- aap
Reply to alexi
- 0 +
>> Nadeem wrote:
>> >> rms
>> > the wattage?
> a
> both
> The
> since
> fixed
>> width font):
<graph snipped>
Not at *all* true. Active power consumption is proportional to frequency
times voltage *squared*. You assume voltage is a constant; it's not. You
also ignore leakage, which is an even higher-order issue, WRT voltage.
We're not in the 20th century, Toto.
> Power
> | 90nm +**
> | 130nm
> +------------------------------------------> 0
> Speed
Would it be nice if life were simple again. ...and June had the meal on
the table when the Ward came home...
Keith
Reply to keith
"alexi" <apredtechenski@austin.rr.com> wrote:
>Dear student Keith with severe deficit of attention, you said:
I foresee a flame, in your future.
Reply to Anonymous
- 0 +
Yeah, easy pickin's though.
Keith
Reply to keith
- 0 +
"chrisv" <chrisv@nospam.invalid> wrote in message
news:7qvkm0p7ue2ckki6bfnvitiqcc05ke177f@4ax.com...
I'am sorry, I didn't mean to offend one of the senior netizens
of this netgroup, just his unwaranted jump on my humble remark
sounded so "studentish". Next time I will research the posting
history and act accordingly :-)
- aap
Reply to alexi
- 0 +
No offense taken. We're all here to learn. However, it *is*
more interesting to learn from those who actually know something. Perhaps
you want to clarify your position? Nah...
Keith
Reply to keith
- 0 +
"keith" <krw@att.bizzzz> wrote in message
news:pan.2004.10.12.02.22.33.878067@att.bizzzz...
> Kidz. Cannot read and will never listen.
> You're ignorant too. It may have been a constant a dozen years ago, and
> perhaps even five. It certainly isn't today. Nothing is a constant.
> Your simpleton formula ignores all reality. (see: leakage)
> You really ought to argue with somone who hasn't been here. You simply
> don't have a clue.
> Ok, I'll be nice and let you show your wonderous experience; how do *you*
> arrive at your wonderous graph for a *SINGLE* model of processor?
> ...the voltage doesn't vary, please!
> Bullshit. You haven't a clue.
> *I* need do nothing. I'm not the newb here. I *do* this for a living.
> You need to listen more and talk less ("what good is ignorance, unless you
> demonstate it" ).
> Oh, my!
> Perhaps you want to 'splain your credentials Lucy? (...no don't you'll
> look even more foolish)
> Keith
I appreciate your deeply-thought response (summarized above).
I think nobody should hit senior netizens and self-taught amateurs,
so I will limit myself to humble submission of my credentials,
although I do realize it might look foolish:
http://home.austin.rr.com/bah/
Have a nice day,
- aap
Reply to alexi
Umm ... shouldn't that be past tense ?
"Did" instead of "do" ?
Thought I read something quite a while back about your
imminent retirement ?
Reply to Anonymous
- 0 +
Nope. Still learning new stuff.
Not yet. I'm still in there, just crossed the threshold where it's my
choice which pocket I want to get paid from. OTOH, another bad
winter, after the summer that never happened, might convince me to think
again. ...consideration given to good offers. ;-)
Keith
Reply to keith
keith wrote:
> alexi wrote:
>> Michael Brown wrote:
>>>> measure the wattage?
>>> There's a difference between running hot and being power hungry.
>>> The Prescott is both (ie: runs hotter and uses more power than the
>>> Northwood), but judging from these results the 90nm A64's are less
>>> power-hungry than the 130nm parts. The jury appears to still be out
>>> good, since they already have a 90nm 3500+) to test the chips at a
>>> large range of frequencies and plot the results. If the results
>>> look like (view with fixed width font):
> <graph snipped>
> frequency times voltage *squared*. You assume voltage is a constant;
> it's not. You also ignore leakage, which is an even higher-order
> issue, WRT voltage. We're not in the 20th century, Toto.
If you've got a few minutes, there's a couple things I'd like clarification
on ... My original graph was drawn on the basis that in modern CPUs, nothing
is ever so nice as to go bad in only a linear way :) The only transistor
physics I have done is for low frequency and theoretical transistors (and
from a physics as opposed to engineering point of view) in which case the
power usage is proportional to the switching frequency, all other things
remaining equal. Assumimg also that modern CPUs are FET-like instead of
bipolar.
What actually happens in the *real* world? Assuming voltage remains
constant, how non-linear (with respect to frequency) is a transistor in the
range that it's typically being pushed in a modern CPU? And what is the main
contributor to that non-lineararity?
Michael Brown
Reply to Anonymous
- 0 +
>> <graph snipped>
Sure, that's why we're here, eh? ;-)
The more things stay the same... ;-)
> The only transistor
> bipolar.
CMOS, certainly. There are few "passive" devices (like bipolar or
N/PFET). ...at least not on purpose. The problem is in the details.
> the range that it's typically being pushed in a modern CPU? And what is
> the main contributor to that non-lineararity?
The "real world" five years ago could be modeled quite like you propose.
The power more-or-less proportional to the *active* CMOS power
equations, much like; P ~ kCFV**2. Forgetting the "static" (or leakage)
power, was easy since it wasn't a big issue (perhaps 10%). The world
changed at 130nm and is getting worse exponentially as the structures
shrink. (If you don't believe me look at the ratio of standby/active
power of a PII vs. PIV at the same voltage.)
Speed is still proportional to the voltage, but the power is proportional
to (at least) the square of the voltage. What's changed is that the static
(leakage) power is now a very significant part of the power budget. Since
leakage isn't a resistive effect (current goes up at a higher rate than
voltage) the power dissipated is even a higher-order function. Leakage
sux! ;-)
There are two major contributors to this power, sub-threshold leakage
(essentially current through the ever-shortening channel when the device
is "off" ), and gate tunneling (current tunneling across the
few-atom thick gate oxide). Both of these currents are a huge function of
voltage. Both can be mitigated by a smart choice of devices and operating
condiditons.
A processor designed for a server may use lower threshold
devices (that leak like hell) and very thin gate oxide (likewise). ...and
pay for it in power dissipation. A laptop may make the oppposite choice.
Indeed within a single system one can control the voltage (the only
independent variable
  • ) depending on the processing needs.
  • suspending clocks doesn't change the power for the work done,
since 'f' is a linear function WRT power/performance.
My issue here is that voltage is *not* a constant. Even the Pentiums had
different voltage ratings across the product line. THe PII made it a
function of the processsor module (but was still static). TMTA (I
believe) introduced the concept of varying the voltage dependent on the
processing needs. This is now a requirement.
A single graph that shows power vs. frequency for a processor
family doesn't show anything close to the whole picture.
Keith
Reply to keith
A few more things.
IIRC Tom Burd's PhD thesis was on the dynamic voltage variance.
(The ex-Berkeley CPU infopad maintainer)
AMD/Intel had to be more conservative in doing dynamic voltage
supply because of more extensive use of custom/dynamic logic.
Some of the non standard/non static CMOS stuff doesn't like to have
the supply voltage change on them very much, but the pressure
to reduce power is leading everyone down similar paths.
Foxton is advertised as the enabling technology for Montecito.
(dynamic frequency/voltage adjustment for power-performance
optimization @ 90nm node)
Without Foxton, Montecito would have ended up having to eat
3X of the power of Madison. (So sayth the "whitepaper" )
davewang202(at)yahoo(dot)com
Reply to Anonymous
- 0 +
news:pan.2004.10.13.03.01.18.706428@att.bizzzz...
> sux! ;-)
> condiditons.
> Keith
You are confused with a bunch of different concepts.
Your first confusions is about "voltage" and "product line".
Voltage is something engineers are using at will, to make
the product work for it's targeted frequency but staying
within reasonable reliability of devices and total power
envelope. The voltage is a variable that you can control
during your experiments with processor clocking and plotting
charts of processor power versus core clock. If you
want to compare two processors, one at 130nm, and another
at 90nm, to see how their power grows with frequency,
you run them at their corresponding _constant_ voltages
(and temperatures), and you get the picture I charted before.
Even if you are correct that "Pentiums had different voltage ratings
across the product line", you still can run each processor
at the same voltage while lowering core frequency down to
get data points. Or increasing frequency, as all overclockers do,
and they do change voltage at will.
If you are trying to compare same (similar? if can find one!)
processors on 0.35um, 0.25um, 0.18um, etc. process along the
frequency axis, then this is a different story, the story called
"CMOS scalability". Then yes, the classic CMOS scalability
is severely broken starting from 0.25um, so the voltages
between process generations are not going _down_ as they are
expected from proportional geometry shrinks (because you can't
shrink transistors proportionally any more because of various
atomic-level limitations). I guess one can call it "non-linear"
shrinks :-(
The original question was, as I read it, "what is non-linear"
with "transistors" as designs are pushed to higher frequencies
(as the original chart clearly implies). The correct answer is that
there is nothing really "non-linear" with CMOS transistor _GATES_.
The whole known methodology of designing processors is still
based on "flip-stay-flop" concept, therefore even today's
processors still follow the basic power formula. A quick
summary of CMOS power consumption basics can be found, e.g. here:
http://www.cse.psu.edu/~vijay/isca [...] ources.pdf
Some (not very nice) discussion about common misconceptions
about leakage, dynamic power, and heat sinks can be found at RWT:
http://www.realworldtech.com/forum [...] m=1224&Thr
ead=1&entryID=14502&roomID=11
You can find there an example of how 0.13um Pentium-4 power scales
with frequency, all based on published specification data for Icc.
From these documents it is clear that I am the last person
who should be accused of "forgetting leakage".
What happens in "real world"? In high-performance processor world,
very simple - you push your design to the limits dictated by
throat-cutting competition, by tweaking geometry, process
corners, voltage, leakage, making thermal slabs and heat-pipe
based heat sinks, all for one reason - to maintain a foothold
in market share. When you hit a wall, everything is very
strongly non-linear - a brick wall :-)
- aap
Reply to alexi
There are 779 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 caljomac won the Freshman badge
  • 13:08 OvrClkr won the Overclocking badge
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
