Yes No
Ads
Tom's Hardware > Forum > CPU & Components > CPUs > Can MEMTEST86+ check memory running at faster bus speed?
Forum CPU & Components : CPUs Can MEMTEST86+ check memory running at faster bus speed?
Archived from groups: alt.comp.hardware.overclocking.amd,comp.sys.ibm.pc.hardware.chips,alt.comp.hardware,alt.comp.hardware.pc-homebuilt (More info?)
I have set my motherboard/BIOS to exceed the normal the bus frequency
by just a little bit. Now I would like to test my memory to see if
it is ok under the new settings.
Memtest86+ from http://www.memtest.org/ looks like a good memory
tester. You make a special floppy and boot from the floppy. So it
tests before Windows is launched.
Does Memtest86+ test memory taking into account my newly chosen bus
frequency settings?
Or does it somehow ignore most motherboard settings (like my
frequency increase) and test the memory "raw"?
[ crossposted. relevant groups]
Reply to Franklin
On Thu, 14 Oct 2004 22:50:30 +0100 There I was minding my own business
>frequency settings?
No software RAM testers are that much use IMHO.Memtest86+ won't point
out anything of relevance in overclocking,none of them will.
My 0.2
Free Windows/PC help,
http://www.geocities.com/sheppola/trouble.html
remove obvious to reply
email shep@obviouspartyheld.de
Free songs to download and,"BURN" :O)
http://www.soundclick.com/bands/8/nomessiahsmusic.htm
Reply to Anonymous
> frequency settings?
The BIOS controls the memory timing, the memory will run at whatever
speed you've set it at. Memtest86 is as good a test as ay to see if your
memory still works. Be advised that by overclocking your system you've
given up timing margins. Just because it works when the room is cool or
when you system is under light load doesn't mean it will work if the room
gets 10 degrees warmer.
Reply to Anonymous
>frequency settings?
There is no such thing as "raw" testing that isn't dependant
on the host device setting the memory bus speed. In other
words, yes it tests "overclocked" settings, which to a
memory module means just another (any particular) speed,
it's all relative.
Reply to Anonymous
>>frequency settings?
>My 0.2
True that software testers are limited in their capabilities but to say
that none will "point out anything of relevance" is absurd and
ill-informed. Have you even tried it?
Memtest86+ is actually a good, if not the best, software based memory
tester. It is certainly a very good confidence check that nothing is
horribly awry and I consider it standard practice to run Memtest86+ for a
couple of hours before attempting installation of an OS. IME, a system
which has passed the checks - as well as a hard disk diagnostic - has
always installed and run the OS without problems.
Rgds, George Macdonald
"Just because they're paranoid doesn't mean you're not psychotic" - Who, me??
Reply to Anonymous
> chosen bus frequency settings?
Yes, chipset/bus freq is set by the BIOS when the machine
boots, not by the OS.
memtest86 is a very good, extensive, memory tester.
It is not a intensive (high bandwidth) as I would like,
so I wrote some in my CPUburn package. Try `burnMMX`.
-- Robert author `cpuburn` http://pages.sbcglobal.net/redelm
Reply to Anonymous
Looks neat.
Does your CPUburn have any special points when compared to the cpu
testers discussed at Radifed?
Like Prime95, Motherboard Monitor's 'Heat Up', HotCPU Tester Pro
Lite, etc.
http://radified.com/Articles/stability_testing.htm
Reply to CrackerJack
> frequency settings?
Has anyone tried Metabench? It is in late beta development and is still
free.
http://www.7byte.com/index.php?page=metabench
Is it any good?
Reply to Anonymous
>>>frequency settings?
>>My 0.2
Yes. Memtest86 performs a series of read writes to the memory and
doesn't bugger about with clock speed as a 'problem detection' feature.
If all the read/writes work, then it gets a pass, if not errors are
reported. It doesn't say 'try lowering your clock speed and see if these
errors go away'. You'll have to figure that yourself :-)
spammage trappage: replace fishies_ with yahoo
I'm going to die rather sooner than I'd like. I tried to protect my
neighbours from crime, and became the victim of it. To jump to the end
of the story, as a result of this I need a bone marrow transplant. Many
people around the world are waiting for a marrow transplant, too. Please
volunteer to be a marrow donor:
http://www.abmdr.org.au/
http://www.marrow.org/
Reply to Anonymous
In comp.sys.ibm.pc.hardware.chips CrackerJack <binaryblobNOTTHIS@hotpop.com> wrote:
> the cpu testers discussed at Radifed?
> Pro Lite, etc. http://radified.com/Articles/stability_testing.htm
I really haven't had much time to look around. If I had the
time, I'd be releasing `burnRAM` [need win32 port] and `burnP7`
[needs some signals work].
It's very easy to get "100% CPU utilization" according to
the OS. `jmp $` or `while(1);` will do. The OS always has
something to run (not the idle thread), so it thinks it's busy.
If you can't get 100% (MS-Win9*), it's a priority issue.
But this is only around 70% of max power draw. Not all the
chip circuits are kept busy. I've crafted my burn* pgms in
assembly (natch!) to try to keep as much busy as possible.
Without any constraint of actually doing useful work!
Some programs can keep the CPU 100% runnable but really not
be compute-limited. Doing useful work is a bit of a limit.
I stuff useless instructions in. SETI@home was notorious for
very odd times for work unit completion (memory fetch bound).
I _don't_ claim my pgms are the hottest possible. I'm sure
that Intel and AMD use better ones as part of their CPU
manufacturing testing. But those are deep dark secrets.
Mine is Open Source.
(email invalid, changed ISP -- you figure it out)
Reply to Anonymous
Press "c" "2" "3" "Enter" to run all eleven tests.
Reply to Anonymous
On Thu, 14 Oct 2004 19:42:07 -0400 There I was minding my own business
>>>frequency settings?
>>My 0.2
Yes.Next to useless and not worth the download let alone running.
Window's itself is a good test of hardware memory.It will balk if
there's anything wrong usually throwing up a,"Registry" fault.
Why some people defend a piece of software that they get for free I'll
never know.Hardware RAM testing machines run into the thousands.Go
figure.
PS
Best RAM test if the user suspects a fault is to swap with a known
good stick ;-)
Reply to Anonymous
Oddly enough I seem to recall a Shep from the K7S5A boards, where
Memtest86 was the recommended tool to identify motherboards that had
"issues" with the higher speed Athlon T-birds. Maybe a different guy...
Rich Webb Norfolk, VA
Reply to Anonymous
In comp.sys.ibm.pc.hardware.chips Shep? <nospam@nospam.net> wrote:
> Window's itself is a good test of hardware memory. It
> will balk if there's anything wrong usually throwing up
> a,"Registry" fault.
Defective software, drivers, and other MS-Windows
cruft can also throw lockups, BSoD & Reg.errs
When these happen, you don't know if it's hardware
or software. Best to have some simple testers that
can rule out hardware. Testers can usually be more
intense than apps or OSes.
-- Robert
Reply to Anonymous
I had unstable system. I ran a Linux based memory tester which booted off a
cdrw or 3.5" disk, and guess what? One of the Dual Channel modules was
malfunctioning, I went to the shop (computeria.fi, mind you) and got
replacement stick no questions asked. It worked flawlessly. Solved the
problem for me.
Yeah. So good. The system was unstable with defective ram, and guess what?
The machine just froze completely randomly, after 2 minutes, 7 minutes.. but
only if using a specific graphics intensive application. Initial reaction
was that maybe the driver is faulty, since that is not unfamiliar thing to
me after using ATI and nVidia products for years. So I switch driver. I
switch card. I switch vendor. Still keeps crashing. For some reason after
hours of tinkering, I somehow just know it is the ram, I download the
tester, burn it to cdrw.. boot with hands trembling.. and what the hell,
defective ram! After getting the sticks (dual channel kit!) replaced,
everything works like charm and has ever since (posting from that very same
system, A64 3000+ K8V DLX).
Latest problem was SP2 upgrade, Windows XP kept bluescreening but MS KB had
article about that, apparently the DEP / NX was broken in Windows XP SP2..
now SP2 works well too thanks for asking. I wonder what breaks next. ;-)
> good stick ;-)
Good idea. Next time I buy a new computer I will buy two dual channel 1GB
memory kits, just in case. No damn, what am I saying.. I didn't listen to
you at all, what I should do is to buy a spare "known good stick", how the
hell I know a stick is a known good stick anyway until I test it? I would
ASSUME that when I pay hundreds of bucks for a known Brand Name stick the
manufacturer would have somekind of quality assurance and testing procedure,
right? I don't know if they do, but sure as hell a defective sticks slipped
through.
So.. how you propose we know what stick is a good one and what isn't? Oh, by
testing? A marvelous idea.. howcome we didn't think of that.. *slaps
forehead* ..
Reply to Anonymous
You do it your way - I'll do it mine and advise others accordingly.<shrug>
Rubbish.
>It will balk if
A registry fault is a memory problem?<guffaw> There's a helluva lot of
other things in both software and hardware which can cause instability in
Windows... or any other OS for that matter.
>figure.
Memory testing software is nothing new - it was used on mainframes and
minicomputers for years. It can generated crafted memory access patterns
which may occur once a day or less in a running OS.
>PS
>good stick ;-)
With a memory tester, even a software one, you'll be closer to *knowing*
that it's the memory. A couple of hours of intensive memory testing,
*before* loading the OS, can save you a lot of grief and time.
Reply to Anonymous
On 15 Oct 2004, S.Heenan wrote:
>> memory tester. You make a special floppy and boot from the
>> floppy. So it tests before Windows is launched.
ISTR there are now 12 tests. Right?
That may well be the case. I can not remember trying extended tests in the
newest version.
I imagine the same keystrokes apply.
Reply to Anonymous
On Sat, 16 Oct 2004 06:23:06 -0400, George Macdonald
<fammacd=!SPAM^nothanks@tellurian.com> put finger to keyboard and
composed:
I agree, but I recall one particularly troublesome memory board in a
minicomputer during the 80's which was not faulted by regular
diagnostic software. This software was very intensive, probably more
so than Memtest-86. It generated many different patterns, and tested
for interference between adjacent memory cells. I ran this software
for several days but was not able to fault the board. However, the OS
and/or application software would crash about once a day with a parity
error. The OS was able to trap the address of this error, but could
not identify the faulty bit. As each bit was stored in a different
DRAM chip, I was facing the prospect of desoldering and replacing up
to 17 chips (16 + parity). Fortunately I eventually narrowed down the
faulty bit after writing a very simple diagnostic routine to exercise
this one location in a tight loop.
The one reservation I have with RAM testing software is that some
appear to have no adequate test for refresh problems. Faulty refresh
logic is more likely to show up in normal use, but not during a memory
test when cells are accessed (and therefore refreshed) continuously.
- Franc Zabkar
Please remove one 's' from my address when replying by email.
Reply to Anonymous
> composed:
> - Franc Zabkar
I can recount a few stories about diagnostic software that missed a
particular type of fault too but that doesn't mean they were useless.
Reply to Anonymous
My MEMTEST (http://home/earthlink.net/~alegr/download/memtest.htm) allows to
check for refresh, by inserting a delay between memory fill and pattern
check runs. The delay can be specified in the command line. For every other
pass it's 2 seconds default, every 63th pass it's 60 seconds by default.
"Franc Zabkar" <fzabkar@optussnet.com.au> wrote in message
news:ji64n0djrsu9st324c42sgmekga51g7ktm@4ax.com...
> composed:
> - Franc Zabkar
Reply to Anonymous
>>point out anything of relevance in overclocking,none of them
>>will. My 0.2
> to say that none will "point out anything of relevance" is
> absurd and ill-informed. Have you even tried it?
> memory tester. It is certainly a very good confidence check
> that nothing is horribly awry and I consider it standard
> practice to run Memtest86+ for a couple of hours before
> attempting installation of an OS. IME, a system which has
It certainly surprised me by how long it seemed to take to do a
check. In fact I had to terminate it as I needed the machine back!
I later tried WinMemTest but it seems very simple by comparision to
Memtest86+.
I want to know if my memory is going into error after I raised the
bus speed.
Reply to Franklin
> running.
I had heard it was one of the best testers.
But how much data corruption might have occurred before Windows
throws up a BSOD? I can't really afford to run the risk of corrupt
data just because I want to use Windows to test my memory in the way
you mention.
> It will balk
> if there's anything wrong usually throwing up a,"Registry"
> fault. Why some people defend a piece of software that they get
> for free I'll never know.Hardware RAM testing machines run into
> the thousands.Go figure.
Reply to Franklin
- 0 +
false sense of security
> you mention.
if there were horrible things wrong with your memory you will know it
long before you test with SW testers.
BSOD tell the tale when they come up. If there are memory registers in
the 'cause' line you will know its memory related.
if you are that concerned about memory errors...use ECC memory
only....
the only way to know for certain is to remove the stick and take it to
a hardware tester. There are memory controllers and many other things
indirectly controlling memory, if this is the area of concern,
software checkers are not up to snuff, and may give you memory errors
that are not chip related, or NOT tell you and you replace mods for no
reason.
"Franklin" <no_thanks@mail.com> wrote in message
news:9585B3DB2DE6F71F3M4@130.133.1.4...
> > running.
> you mention.
> > It will balk
Reply to jad
On Sun, 17 Oct 2004 04:10:44 -0500, David Maynard <dNOTmayn@ev1.net>
put finger to keyboard and composed:
>> composed:
>> - Franc Zabkar
I did not mean to imply that at all. My anecdote was intended to
demonstrate that memory faults can be quirky and highly intermittent.
The diagnostic software I was using was very thorough - it just wasn't
"lucky" in this particular case.
As for refresh problems, I notice that the latest version of
Memtest-86 now has a "bit fade" test (test 12) which appears to target
these types of faults. Unfortunately my system bombs early on in this
test with an "unexpected interrupt error". :-(
FWIW, the old minicomputer memory diagnostic also had a test which
used the "Knaizuk algorithm". I haven't heard of this technique in
modern software, though. Perhaps this algorithm is not as useful in
testing modern DRAM architecture???
- Franc Zabkar
Reply to Anonymous
On Sun, 17 Oct 2004 10:22:09 -0700, "JAD"
>> you mention.
Not if you are wise. Wise tech never boots windows if the
memory stability is in question. One single boot is enough
to trash a windows install from memory errors.
Nope, often registers are mentioned with no physical memory
error... just had one the other day related to MS
Messenger, which user had left enabled.
>only....
.... and then there's the better-than-nothing approach, to at
least make sure the box in front of you, as configured, has
no errors before corrupting any data. "Best" is always nice
but you wouldn't want to ignore testing the memory if it
were ECC either.
>reason.
True, but it doesn't necessarily matter. Memory module "X"
won't work in board "Y", then it has to come out regardless
of what's to blame. Within the expensive hardware tester
another module is tried instead... It's pointless to even
mention hardware memory testers since less than 0.1% of the
techs out there have access to one.
Reply to Anonymous
On Sun, 17 Oct 2004 16:31:22 GMT, "Alexander Grigoriev"
<alegr@earthlink.net> put finger to keyboard and composed:
>My MEMTEST (http://home/earthlink.net/~alegr/download/memtest.htm) allows to ...
Your link appears to be broken. This link works for me:
http://www.home.earthlink.net/~ale [...] emtest.htm
>... check for refresh, by inserting a delay between memory fill and pattern
- Franc Zabkar
Reply to Anonymous
oops.. put a slash instead of period...
news:jnl5n0tpe83bg2v5mf3i28eocrlq72k9us@4ax.com...
>>to ...
>>pattern
>>other
> - Franc Zabkar
Reply to Anonymous
Snipping to create context you can argue with is a nasty Usenet habit.
>> you mention.
Again...RUBBISH!
>only....
Once "validated" through testing, diagnostics and a few days of running
with an OS, modern memory modules are generally good for years of reliable
use...IME. ECC has its place of course... which is slightly different from
initial checking/validation.
>a hardware tester.
<sigh>We all have to start somewhere when dealing with a newly built system
- memtest86 does a reasonable job and serves its purpose. It's simply part
of a proactive approach to system integrity at time of build and
installation.
This is simple stuff: we have a mbrd from one supplier, a CPU form another
and memory modules from a 3rd, all supplied with power from a 4th. Why
anyone would want to argue with the concept of running some diagnostics as
a first step beats me... possibly you rely on Dell to do that for you??Ă´_Ă´
>reason.
Hmm, seems to contradict what you just said about registers and memory
errors.<shrug> Then again, it depends on the system - AMD64 systems have
no "other things" between the CPU package and the memory, other than the
mbrd traces and sockets.
Reply to Anonymous
- 0 +
go ahead gmac play at it...
"George Macdonald" <fammacd=!SPAM^nothanks@tellurian.com> wrote in
message news:lp26n0tmv3so37rqfgg8hgo4pif4k60qhg@4ax.com...
habit.
corrupt
way
> >> you mention.
it
in
> Again...RUBBISH!
> >only....
running
reliable
different from
to
> >a hardware tester.
system
simply part
> installation.
another
Why
diagnostics as
you??Ă´_Ă´
errors
no
> >reason.
memory
have
the
Who, me??
Reply to jad
Better than blind faith.
Or you could corrupt what you write in the hard-drive installed on your
system long before you find out you have a problem with your memory.
What makes you think you have any right to expect a bluescreen at all? I got
a complete lockup as reward for my troubles half of the time, and half of
the time, *blink*, a happy, quick reset. Testing the memory found the
problem very quickly after hours of taking the new system apart. Should have
done that first, not last.
> only....
No one is 'concerned' about memory errors, merely aware of the possible
problem and following a good, solid practises to make sure that cheap
consumer parts work as advertised. You just need to be in the shitty
situation yourself, once, and you will not it find so easy to be clever
afterwards when someone else had problems.. and this should be a no-brainer,
since the solution was handed to you on a silver platter.
Not everyone here owns, or has easy access to a hardware memory tester.
Guess what? I don't have eeprom burner either here with me, shocked?
But not the only way to find problems. www.simmtester.com has following to
say on the topic:
"Hardware Memory testers are designed for PC service professional who need
to test relatively high volume of modules and not for those who test only
one or two modules. "
> reason.
Display driver trouble is wevy wevy wevy common in Windows(R) </Elmer Budd's
voiceover>, from the symptoms you would think that it is hardware failure--
software such as display driver can crash Microsoft Windows(R) and go to the
nearest hardware tester. The hell you would, you would try to resolve this
"software problem" first-- how many times you have had malfunctioning memory
anyway? What have you done in one or two instances care to share with us?
Don't tell me. You did go directly to the hardware memory tester only to
find out that the memory works perfectly didn't you? :)
Reply to Anonymous
- 0 +
Top-posting kidz. <yawn>
Keith
Reply to keith
- 0 +
yeah and for every specific instance you named I could name others
that support my views then you then me so on and so on..if you want to
sit in front of a memory tester(software) because you fear your data
may be corrupt in the future due to memory problems go for it. Let
your machine be useless for that time...test the cooling of your
memory and case..to find out that after all night of running it while
you slept with your head on the desktop, drooling all over the mouse
pad, the system rebooted and didn't save a log.
"assaarpa" <redterminator@fap.net> wrote in message
news:ckv9h4$fv3$1@phys-news1.kolumbus.fi...
it
your
registers in
all? I got
half of
the
Should have
> > only....
possible
cheap
clever
no-brainer,
tester.
it to
things
following to
> say on the topic:
who need
only
errors
for no
> > reason.
</Elmer Budd's
failure--
go to the
resolve this
with us?
only to
Reply to jad
- 0 +
kieth the top posting thing is real old....... if that's all you have
to say best just to keep it to yourself. You also insist that people
read only a certain way? Or stop to think that maybe due to my
accessibility settings and hardware, its more convenient for me to
post this way?
The nazis of the usenet never take into consideration the
disabled....wonder why? You group yourself with them?
"keith" <krw@att.bizzzz> wrote in message
news:pan.2004.10.18.02.38.16.846379@att.bizzzz...
> Keith
Reply to jad
What you are saying is writing off software memory testers right out of the
picture and actually RECOMMEND a hardware memory tester, not a particularly
cheap piece of hardware. I got interested, please DO name a situation where
it would make sense for a normal guy without access to hardware memory
tester to explicitly start looking for one instead of simply using a
software memory tester to eliminate one possible cause for BSOD.
If you are not concerned about your data, why are you recommending a
hardware memory tester, isn't that a stretch overkill if you wouldn't care?
Would have saved me hours of taking the system apart and little by little
converging to the correct diagnosis. With your proposed method, wouldn't be
the wiser what is causing the BSOD-- only thing I know for sure is that I
have to either mail, or take the memory modules personally to the nearest
place where I, or someone else, can perform a hardware memory test to very
likely negative results.
Also, if your machine time is to valuable wouldn't it make sense to have the
problems diagnosed as quickly as possible? You just cannot hand advice like,
"when Windows BSOD's and there is memory address mentioned as cause" to run
for the nearest hardware memory tester. That is idiotic to say the least.
Sure if the tester is in the same building maybe, beyond that, little
judgment is required to put things into perspective. That requires something
you seem to have a very short supply of.
Nothing similiar to this took place, you're pretty desperate aren't you?
Reply to Anonymous
Like your previous creative avoiding the arguments he put down.
>You also insist that people read only a certain way?
Yeah! English is written left to right, top to bottom. Often people read
English the same way it is written, why we might never learn the awful
truth.
> post this way?
You are using Outlook and why you post that way is that you haven't mastered
shift-cursor / delete yet, poor baby.
What, your delete button is broken?
Reply to Anonymous
- 0 +
go to the
resolve this
with us?
all kinds of immature ranting clipped
exactly how many times is a BSOD caused by memory errors? (other
than ACCESS errors CAUSED BY ill written SOFTWARE/DRIVERS)
of course, if i suspected memory, I would be off to the hardware
tester,, that would be the most effient way of handling it.... but
again how many times have i needed to do that as related to BSOD's in
any Windows OS? 2%.or less...........
what your new presciption not available on your discount card? aarp
Reply to jad
>>>composed:
>>>- Franc Zabkar
OK. I was looking at it in the context of other messages claiming that
memory tests were useless and misinterpreted your intent.
Murphy's Law. hehe
My 'un lucky' incident was while preparing a demonstration for a class on
the memory diagnostic and it failed to find the defect. (woops).
Very possible since when the technology changes so do the failure modes.
> - Franc Zabkar
Reply to Anonymous
On Sun, 17 Oct 2004 20:09:17 -0700, "JAD"
>post this way?
Translation -
You're using OE, which doesn't function correctly as a
newsreader. It is not "real old".
Reply to Anonymous
On Sun, 17 Oct 2004 20:55:11 -0700, "JAD"
>go to the
>resolve this
>with us?
Sadly you still don't GET it.
It is, to a certain extent, irrelevant if it passed in a
(hardware) memory tester, if it fails in the system it's to
be used in. Even if you do test the memory in a tester, you
STILL _MUST_ test it in the machine it's in, else you've
skipped the most important part. If i had a memory tester
in front of me and had to choose testing ONLY in the tester
or the target motherboard with memtest86, then memtest86
would win hands down... only after a motherboard + software
test fails is the hardware tester worth spending any time
on.
Reply to Anonymous
Whaaat? You want me to explain the difference between proactive and
reactive?:-[]
Reply to Anonymous
"JAD" <Kapasitor@coldmail.com> wrote in message
news:10n6flhmaa482ac@corp.supernews.com...
> go to the
<snip>
I can't believe your all still arguing with this troll...
- It's STUPID to use your working environment to test memory (ie, wait for
BSOD while using Windows)
- There is nothing wrong with running software like Memtest to actually test
memory. If it finds an error, then you have something to work with. If it
doesn't you may still have bad memory, but it's much less likely.
- Having spare parts around is always helpful, especially when trying to
diagnose an intermittent issue, but buying spare parts "just in case" when
you get your PC is dumb (except in the case of mission critical servers)
- Buy reasonable quality parts and you shouldn't have any major issues. If
you do have issues, go slowly, doing the simple tests first and eliminating
different subsystems. Memtest is GOOD for this.
....enough children!
Reply to Anonymous
- 0 +
various pages NON bias non xinux non GNU web pages
The software solutions don't work - it is constrained to test only at
the speed it's controller works at and can't do the low or high
voltage test
But like many other memory testers out there, Memtest86 is unable to
test 100 percent of a computer's memory.
.. again, no diagnostics detected any errors. Finally, I set the CAS
Latency to 2, and some errors began to pop up. RST, RST Pro and
GoldMemory all identified the errors fairly quickly (though RST passed
it in about half of its runs). MemTest86, however, never identified an
error, even after running for 24 hours solid.
MemTest86 is certainly more than adequate for the home user and
hobbyist that does not keep extremely critical data on his/her system
tested with only 2 RIMMs installed, just to make sure that the board
itself and the memory would pass in an officially sanctioned
configuration. None of the diagnostics detected any errors. I then
installed the third RIMM, and threw the diagnostics at it. Both
GoldMemory and MemTest86 ran for 24 hours without detecting a single
error.
GNU / linux that would figure and explains the obsession, NO WONDER
there are the fanatics...............
"kony" <spam@spam.com> wrote in message
news:ogt6n058ddvcjuuiv8n312rhtsbegqj0or@4ax.com...
have
people
> >post this way?
> Translation -
Reply to jad
On Mon, 18 Oct 2004 08:51:12 -0700, "JAD"
>voltage test
>error.
No software tester is perfect, nor is hardware testing
without followup using software tests on the target system.
Even so it is prudent to do so and many people catch errors
they might've otherwise missed with software testers like
memtest86.
Reply to Anonymous
- 0 +
> reactive?:-[]
Cat's got it's tongue.
Keith
Reply to keith
In comp.sys.ibm.pc.hardware.chips JAD <Kapasitor@coldmail.com> wrote:
> Then I gave you some knowledge about why I'm a little stuck
> with it, and you attack my disability
It appears your physical disability has affected your emotions
and mental processes. It compounds the tragedy, but you might
be able to find some help in support groups. Otherwise, you just
make your difficult life still moreso by aggression/alienation.
My sincere sympathies,
-- Robert
Reply to Anonymous
- 0 +
no robert i let low lives bother me................that was the
mistake.........and your 'under your breath'
put downs makes you the same. Just because you have the ability cloud
your rudeness in diplomacy doesn't make you any better. running for
office?
"Robert Redelmeier" <redelm@ev1.net.invalid> wrote in message
news:G0add.7522$Al3.4795@newssvr30.news.prodigy.com...
> -- Robert
Reply to jad
In comp.sys.ibm.pc.hardware.chips JAD <Kapasitor@coldmail.com> wrote [reformatted]:
> no robert i let low lives bother me ................ that
> was the mistake ......... and your 'under your breath'
> ability cloud your rudeness in diplomacy doesn't make you
> any better. running for office?
Learning how not to be bothered by others is an important
life-skill for everyone.
I'm sorry you think you see "put downs" in my post.
I assure you, none are intended.
-- Robert
Reply to Anonymous
.... some PLONKEE wrote something or other ....
However I assure you I intend any put-downs, due the the PLONKEEs
rudeness, crudity, and top-posting. It is obviously a fairly low
life form.
"I support the Red Sox and any team that beats the Yankees"
"Any baby snookums can be a Yankee fan, it takes real moral
fiber to be a Red Sox fan"
"I listened to Toronto come back from 3:0 in '42, I plan to
watch Boston come back from 3:0 in 04"
Reply to Anonymous
On Mon, 18 Oct 2004 05:24:16 +0300, "assaarpa" <redterminator@fap.net>
I was thinking along the same lines. If a memory error occurs in
program code, then I would expect to see a BSOD, or a lockup. OTOH, if
bad RAM results in the corruption of a data region (eg spreadsheet or
text document), then you may get no warning at all.
- Franc Zabkar
Reply to Anonymous
Previous
1 2
There are 1868 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What case should i get? Between these 3 with my build?
By amuffin, 38 minutes ago:
They will all work, but I would grab the HAF 912. This is because I've owned the 912 and...
Best offers
Top experts
