G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
Hi, I have a funny problem on my eMachines (FIC AM39L motherboard, Via
KM400A chipset) with memory.
I recently got 512MB Kingston memory to add to my 512MB Samsung memory
that came with the system.
I put the Kingston in the first slot, and the Samsung in the second, and
my system was flaky.
I switched them, and my system was stable, but I wanted to make sure and
got MEMTEST-86.
With 1 gig installed, I am getting a few errors on test 5 (never the
same amount, and never at the same place).
With either chip in the first slot, I get no errors at all!!!!!
Is there a way I can diagnose what is going on? Could the extra memory
be dragging down the amount of power causing the problem?
Or what else could be the problem? The system seems stable enough now,
but I am not very comfortable with MEMTEST-86 failing (only on test 5).
Thanks for any advice,
Larry
got MEMTEST-86.
Larry
