Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
I know upfront this is a way old and slow board, but not much I can do about
that.
Anyway I have what's identified by Belarc Advisor as an Hsing 586TX Rev 3.1
motherboard. The AMI BIOS is 0626, 7/15/1995. The processor was upgrade
to a 200Mhz processor, but the bios did not recognize the change nor do I
see a way in the BIOS settings to change the processor speed. After
searching the net a bit, I see on these old motherboards changed processor
speeds were often needed to be set via jumpers on the motherboard. I found
the voltage changes for the processor, but I can't find where to change the
processor speeds. I also don't know what jumper settings are needed to
identify to the motherboard that now a 200Mhz processer is present
(previously it was 166).
Pozdrawiam.
RusH //
http://randki.o2.pl/profil.php?id_r=352019 Like ninjas, true hackers are shrouded in secrecy and mystery.
You may never know -- UNTIL IT'S TOO LATE.
Your 166 was jumpered as 2.5x (66MHz) your new processor should be jumpered
as 3x 66MHz
Look for words on the board like 1x 1.5 x 2 x 2.5 x 3 even 3.5 which would
make it run at 233MHz. You might be lucky.
Regards, Steve
"Joe Magiera" <joemagiera@ameritech.net> wrote in message
news:icJDd.12055$_X7.108@newssvr33.news.prodigy.com...
about
> that.
3.1
found
the
> Can anyone help? Thanks in advance,
> Joe
