Need motherboard(s) with 3.3V, 66MHz PCI slot(s)
Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
Anyone know of any? I need the 3.3V keying at a minimum (card won't
fit, otherwise), 66MHz capability strongly preferred.
5 answers Last reply
More about need motherboard 66mhz slot
  1. Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
    Well, I found some Xeon boards pretty quickly. Standard-ATX-sized and
    cheaper CPU would be better...
  2. Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
    Hmm... Supermicro P4SCi might work. It's got two 64-bit, 66MHz PCI-X
    slots, which I think will work with a 66MHz PCI card.
  3. Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
    The Tyan S288x, S4882, and S289x boards all have 3.3V PCI-X slots.
  4. Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
    Thanks. I found that if you look at server boards, it's a really
    common feature. The hard part was finding a *$@#&%! power supply that
    for sure matched the mobo.
  5. Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
    http://www.pcpowercooling.com/products/power_supplies/maxperformance/index.htm
CPUs Hardware PCI Motherboards
