Tom's Hardware > Forum > CPU & Components > CPUs > CPU Temperature and Fan Speed for Phoenix Bios D686.
Forum CPU & Components : CPUs - CPU Temperature and Fan Speed for Phoenix Bios D686.
Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
Hi,
Is there a free tool API or library avaiable to read the CPU
temperature and the FAN speeds once the Windows is up and running?
The BIOS shows it at the booting time, I like to get it once the system
is up and running.
Appreciate any help.
Sam
Sponsored Links
On 28 Apr 2005 07:55:14 -0700, "Ohm" <sams@freeddns.org> wrote:
>Hi,
>is up and running.
I've seen Speedfan recommended by several people but you'll need to check
if it covers your mbrd and its monitoring chip, which you can determine
with Sisoft's Sandra. Check out www.majorgeeks.com for both.
Rgds, George Macdonald
Reply to Anonymous
Bitstring <1114700114.476948.204870@z14g2000cwz.googlegroups.com>, from
the wonderful person Ohm <sams@freeddns.org> said
>Hi,
>is up and running.
If an application will do (rather than an API or library call) try
Motherboard Monitor 5 (for most, but not all, motherboards/chipsets)
GSV Three Minds in a Can
Contact recommends the use of Firefox; SC recommends it at gunpoint.
Reply to Anonymous
There are 851 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 caljomac won the Freshman badge
  • 13:08 OvrClkr won the Overclocking badge
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
