Low-end PSUs always dissipate the max rated power?
Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
Hello everyone,
I'm rather confused over something I was told today.
Low-end PC power supply units always dissipate whatever power they are
rated for, e.g. a 400W PSU will always dissipate 400W whether the system
is idle or not. If the system does not need the power, then that power
is dissipated as heat (?!?). That would make the power saving features
on modern CPUs almost moot, no?
Is it true? Are PSUs, even cheap ones, able to provide whatever power is
needed up to the limit, or do they always crank out the max?
Regards, Grumble
6 answers Last reply
More about psus dissipate rated power
  1. Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
    On Fri, 03 Jun 2005 12:32:37 +0200, Grumble <devnull@kma.eu.org> wrote:
    >Hello everyone,
    What nitwit told you that? A salesdroid at Best-Buy?
  2. Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
    >>Hello everyone,
    The guy selling 400W zener diodes.
    Even they know where the awning is when it rains.
    Keith
  3. Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
    > power they are rated for, e.g. a 400W PSU will always
    > dissipate 400W whether the system is idle or not. If
    The person who told that to you had absolutely no understanding of how
    power supplies work because if it were true, then supplies would be
    hottest at zero load. Try simulating this by installing lightbulbs
    totalling 400W in a small ventilated metal box with a fan blowing air
    through it, an it should become unbearably hot in a few minutes. Even
    linear supplies, which regulate voltage by intentionally turning
    unneeded power into heat (essentially like regulating the speed of the
    car through the brakes), don't get hotter at lower loads. For an
    explanation of how computer supplies work, try
    http://computer.howstuffworks.com/power-supply.htm
    Cheap and expensive computer supplies operate basically the same way,
    only the cheap ones usually don't work as well (can't put out as much
    power, voltages regulated worse, overload protection fails), major
    exceptions being those from Fortron-Source, which are among the best
    but often also among the cheapest.
  4. Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
    >Hello everyone,
    Don't tell us.... this guy has a tube amplifier in his home theater
    system?:-)
    Rgds, George Macdonald
  5. Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
    Haven't been able to find any "cheap" Fortron PS's over 400W anywhere.
    <do_not_spam_me@my-deja.com> wrote in message
    news:1117890297.469900.269470@f14g2000cwb.googlegroups.com...
  6. Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
    They're relatively cheap, but a 350W Fortron will usually put out as
    much as a typical major brand 400W.
CPUs Power Supplies Power
