Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
Frederick wrote:
> I'm trying to confirm that it's safe to connect a new-style PSU with 24-pin
> motherboard power connector to an old Pentium PIII 20-pin socket.
> I've noticed that the connector will physically connect with the board's
> 20-pin socket.
> I realise that I can purchase another power-supply but I need to find out
> quickly, so that I can get a system up and running again tonight.
Yes, it should be fine. Just make sure you put the right twenty in it.
>20-pin socket.
Yes they are compatible but... there are apparently some mbrds which want a
-5V power connection, which is not part of the ATX12V 2.0 specs. Check
first. You can check out the different pin arrangements here
http://www.power-on.com/ - look up a P/S and hover your mouse pointer over
the connectors to see the pin-outs.
> 24-pin motherboard power connector to an old Pentium PIII 20-pin socket.
> 20-pin socket.
> Thanks!
ot but wouldnt a 24 pin psu cost more than the rest of your pc combined,
mind if i ask why you are using it
