Tom's Hardware > Forum > Systems > Gateway2000 > Need WinMe programming interpretation/help
Forum Systems : Gateway2000 - Need WinMe programming interpretation/help
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
I got a WinMe initializing device CONFIGMG... Windows Protection Error;
and below you can see why. These are the last entries in my BOOTLOG.PRV
file, where the MS knowledge base says my problem would be listed.
[000B8C00] DEVICEINIT = CONFIGMG
[000B8C00] Starting Unknown (HTREE\RESERVED\0)
[000B8C00] Started Unknown (HTREE\RESERVED\0)
[000B8C00] Starting Unknown (HTREE\ROOT\0)
[000B8C00] Started Unknown (HTREE\ROOT\0)
[000B8C00] Enumerating Unknown (HTREE\ROOT\0)
[000B8C01] Enumerated Unknown (HTREE\ROOT\0)
[000B8C01] Loading PNP drivers of Plug and Play Software Device
Enumerator (ROOT\SWENUM\0000)
I had to remove Real Player 10, from my system to restore some
stability, and the ability to start up without a floppy boot disk.
Could this be a remainder from my system conflicts with that program?
Regardless... would it be safe to remove the entries identified as
UNKNOWN? What is CONFIGMG for ... the system, or one application?
I haven't had any success with previous inquiries in the WinMe software
groups, so I thought I would try my luck here. I know we have some
Gateway experts who may be able to educate me. Please...?
TIA for any advice.
bj
Sponsored Links
There are 1296 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
