Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
I have a Niece who has an older Gateway performance 600 with win 98
installed. All of a sudden it started getting an OE fatal exception error
0167 bff92094 and windows will not boot. I tried safe mode same thing and a
win 98 boot disk no good either. In checking the bios the hard drive is not
being seen. However and this is the strange part, I can access C: from the
win 98 boot menu command prompt only. I tried disconnecting the drive and
reconnecting. No luck the bios still can't detect it yet I can here it
spinning and see it from the command prompt.
The file system seem to be intact. Anyone have any ideas?
Replace the C2032 3v lithium battery with a new one. Battery failures cause
strange symptoms. That's my best guess. Batteries are cheap. It's worth a
try as the first attempt to get the system back in the running... Ben Myers
On Wed, 25 Aug 2004 23:19:11 -0400, "Brian" <briancloutier@comcast.net> wrote:
>Thanks,
>Brian
Can you get to c: prompt?
Then type scanreg /restore
select a restore point
>Thanks,
>Brian
Download the test utility from the drive manufacturer and do a thorough test
if you can get the drive to be recognized - it sounds like you have a dying
hard drive.
"Brian" <briancloutier@comcast.net> wrote in message
news:c5qdnbThloUty7DcRVn-qg@comcast.com...
error
a
not
the
> Thanks,
> Brian
Tried scan reg no good. Will try the battery!
Thanks,
Brian
"FB" <mixxitdj@netscape.net> wrote in message
news:9ZcXc.21233$N11.13692@bignews5.bellsouth.net...
error
and a
not
the
and
> >Thanks,
> >Brian
