Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Help: Adjusting brightness on IBM (Sony) monitor
Forum Graphic & Displays : Graphics Cards - Help: Adjusting brightness on IBM (Sony) monitor
Archived from groups: comp.sys.ibm.pc.hardware.video (More info?)
Hello folks,
I have an IBM 21" monitor with Sony WEGA tube (model P260).
The image is too bright, and on-screen menu brightness control
range is insufficient to achieve comfortable brightness. Even when
set to 0, the image is way too bright to use the monitor. I don't
see any other problems with the monitor.
Is there any way to lower the brightness? I've often been able to
use internal controls in such cases. Many monitors have
focus / brightness adjustment knobs on flyback transformer
(if that's the right term). This one has two focus controls
instead (they do work).
Anybody knows where global brightness regulator is inside,
for IBM monitors with Sony tubes?
Thanks in advance for any tips.
garg444NOSPAM@yahoo.com (remove NOSPAM to reply).
Sponsored Links
There are 777 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
