Monitor Doesn't Turn-on When Hot
Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
At the nearby computer junk place, http://www.surplusexchange.org/, I got a
HP A4033A 19" monitor
http://www.griffintechnology.com/archive/monitors/Hewle12.html for $22. It
works okay until you turn it off. Then if you try to re-turn-on soon, the
Power Saving indicator comes on and the monitor doesn't. If I wait for it to
cool (I really don't know if temperature is the factor), and then turn-on,
it works normally. So should I put a fan on the vent holes? Or what should I
do, if I should do something?
* Nehmo Sergheyev *
15 answers Last reply
More about monitor doesn turn
  1. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
    "Nehmo Sergheyev" <nehmo54@hotmail.com> wrote in message news:<2da3d.23847$B51.21369@twister.rdc-kc.rr.com>...
    > I got a HP A4033A 19"
    > for $22. It works okay until you turn it off. Then if you try
    > to re-turn-on soon, the Power Saving indicator comes on and
    > the monitor doesn't. If I wait for it to cool (I really don't
    > know if temperature is the factor), and then turn-on, it
    The monitor already has all the vent holes it needs, and I haven't
    heard of a monitor needing a fan, except for the old Zenith Flat
    Tensioned monitor.
    I'm rather certain that your monitor has an overheated resistor or
    solder joint that makes contact when cold but expands and opens up
    when hot. Any such resistor (may be burned or bulged) has to be
    replaced (match resistance and tolerance ratings, and meet or exceed
    power rating), but resoldering bad joints will restore them (add fresh
    solder so its rosin will clean any oxidation). Cracks can be
    invisible to the naked eye and require a magnifying glass to find, so
    some technicians simply resolder everything, or at least everything
    connected to components that are subject to mechanical stress
    (connectors, heavy objects) or that run hot. I'd especially look for
    bad solder around a thermistor because they normally run very hot. It
    usually resembles a ceramic disk capacitor (normally green or black)
    or may be a flat disk with wires welded to its sides. The circuit
    board may be labelled TH, THERM, or NTC next to it.
    www.repairfaq.org has a great deal of information about electronics
    repair and precautions. Unplug the monitor from the AC outlet before
    removing its cover, don let the monitor fall forward (it's
    front-heavy), and don't bump or scratch the picture tube because it
    can implode and then explode with enough force to shoot shards that
    will lodge in the walls or your eyes.
  2. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
    In comp.sys.ibm.pc.hardware.misc Nehmo Sergheyev <nehmo54@hotmail.com> wrote:
    Likely thermal or capacitor problem. You can try all sorts of
    things, but the only reliable approach is a circuit-level
    diagnosis of the problem. Might require a degree in EE to
    be done properly.
    Be careful before you change anythong on the inside, tamper with
    electrical insulation or operate it without cover: There is both mains
    voltage (possibly rectified and stepped up to 300V) and high-voltage
    (15000V...30000V) in there. Both can kill you if you are unlucky.
    Arno
    For email address: lastname AT tik DOT ee DOT ethz DOT ch
    GnuPG: ID:1E25338F FP:0C30 5782 9D93 F785 E79C 0296 797F 6B50 1E25 338F
    "The more corrupt the state, the more numerous the laws" - Tacitus
  3. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
    - Arno Wagner -
    - Nehmo -
    What's peculiar about the problem with this monitor (and I've only been
    using it for two days) is that if it continues to be on, it will stay on. It
    only fails if you remove the power or otherwise turn it off. Then it won't
    come back on, but, when turned back on, goes into *its* Power Saving mode
    (the Power Saving indicator on the monitor goes on).
    If the problem were just heat, wouldn't it fail while running?
    Also, even though I found a driver on Driverguide
    http://members.driverguide.com/ , I can't seem to install it. In the Add
    Hardware Wizard, if I select HP or Hewlett Packard, the monitor isn't
    listed, although plenty of other HP products are. What am I doing wrong? And
    can I run the old monitor even after I get this HP driver installed?
    * Nehmo Sergheyev *
  4. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
    "Nehmo Sergheyev" <nehmo54@hotmail.com> wrote in message news:<Ntu3d.52836$6h7.39943@twister.rdc-kc.rr.com>...
    > (and I've only been using it for two days) is that
    > if it continues to be on, it will stay on. It only
    > off. Then it won't come back on, but, when turned
    > back on, goes into *its* Power Saving mode (the
    It could be the kick start circuit in the power supply,
    which is needed only at turn-on, but if it's going into
    power saving mode under the wrong conditions, check the
    setup of the computer (turn off the power saving mode or
    change the monitor turn-off mode to "blank screen")
    (their absense activates power saving modes for the
    monitor). The power-saving circuitry could have a flaw,
    such as a bad connection or part that fails after it
    heats up (very slight, fan won't help). But don't throw
    away this monitor because any flaw is probably an inexpensive
    repair, provided the labor is free.
  5. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
    On Sun, 19 Sep 2004 07:05:34 GMT, "Nehmo Sergheyev"
    <nehmo54@hotmail.com> put finger to keyboard and composed:
    I would be looking for dried out electrolytic capacitors, probably on
    the primary side of the power supply.
    - Franc Zabkar
    Please remove one 's' from my address when replying by email.
  6. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
    - Manny -
    - Nehmo -
    How do you change the turn-off mode to blank screen? Desktop > Properties >
    Screen Saver > Power button > Power Schemes > There's only a drop-down for
    how long to wait before turning off the monitor.
    Is there something somewhere else, like in the BIOS?
    - Manny -
    - Nehmo -
    Even in it's current condition, I won't throw it away. I just have my old
    monitor handy should this one fail.
    Actually, it seems when the computer turns the monitor off (lack of activity
    for 30 minutes in the power settings), it comes back on without a problem.
    It appears the problem happens when I turn it off via the button or plug. I
    don't want to experiment now. I'm using it at the moment.
    * Nehmo Sergheyev *
  7. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
    > - Arno Wagner -
    > - Nehmo -
    Yes, unless it is heat in a circuit that needs only to function
    when the monitor is turned on. The whole problem sounds very much
    like an issue with the power-up circuit. Unfortunately that is
    hard to diagnose.
    No idea, sorry.
    Arno
  8. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
    > But don't throw
    Yes, true. But a qualified EE costs a lot per hour. It could
    be that such a level of competence is needed to repair this problem.
    My advice would be to live with the problem and only if it gets
    worse to try to repair it.
    Arno
  9. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
    Arno Wagner <me@privacy.net> wrote in message news:<2r5r44F16kn24U1@uni-berlin.de>...
    > be done properly.
    I have the opposite of an EE degree, a sociology degree. Not only
    that, but m degree came from AZ State instead of a real college. Yet
    I've fixed several monitors that were tossed by other people (the last
    monitor I bought cost negative $30, after rebates), and almost always
    the problem was minor, like a solder connection, capacitor, or shorted
    transistor. I think that if I can fix monitors, then almost anybody
    can.
  10. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
    In comp.sys.ibm.pc.hardware.misc larrymoencurly <larrymoencurly@my-deja.com> wrote:
    >> be done properly.
    > can.
    Depends on the problem. I am doing electronics as a hobby for
    20 years now and I know that many problems can be diagnosed
    without tools, because the component that is broken is obvious.
    I said "the only reliable approach". If you have the time
    and are a bit lucky, many electronics faults can indeed be
    fixed with common sense and some dexterity. Others are hard to
    find with experience, special equipment and an EE degree.
    The case described by the OP sounds like such a hard case to me.
    More like a subtle problem, e.g. a capacitor having lost some of
    its capacity but not all or a circuit damaged parially by static
    electricity.
    Arno
  11. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
    >>> be done properly.
    >> can.
    >electricity.
    Or a part that you know is bad, but you can't find a replacement.
    Last time I tried to fix something of my own (an audio power amp), I
    traced it to an NEC transistor that was impossible to find information
    on or replacements for.
  12. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
    chrisv <chrisv@nospam.invalid> wrote in message news:<f803l0helkqk92smpqg91ko2gjg3lidb3s@4ax.com>...
    > >electricity.
    www.bdent.com has a lot of data sheets, but they're under
    "schematics".
    Another place with information and parts for audio amplifiers is Audio
    Lab of Georgia, and www.nteinc.com may at least give you the
    parameters for transistors and diodes. As for web searches, I've had
    much better luck by Googling the part number than by looking for
    electronics websites, but sometimes adding "semiconductor" to the
    company name will bring up their database, i.e.,
    www.necsemiconductor.com (I don't know if that's an actual website),
    but for Sanken you have to go to www.allegromicro.com.
  13. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
    >>>> be done properly.
    >>> can.
    >>electricity.
    Yes, sometimes I think they do it on purpose. The last semiconductor
    that failed on me was the chipset in my Sony Vaio. Sort of a
    self-destruct mechanism, since it was inadequately cooled by
    design. O.k., that is another issue.
    One thing I seems to see a lot though is unmarked or insufficiently
    marked chips and other components. Like they do not want these things
    to be repairable.
    On the other hand I had very little electronics failures in the
    last years. The Vaio does not count, since that failure was obviously
    engineered. I will never buy Sony computing equipment again, being
    ripped off once is enough. Before that the las one I had were
    fauly capacitors (in several instances). AFAIK this was a single
    incident of industrial espionage gone wrong and was easy to
    fix in all instances (except the one were I mismatched capacities
    enough to get a resonance effect).
    Arno
  14. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
    On Wed, 22 Sep 2004 08:43:49 -0500, chrisv <chrisv@nospam.invalid> put
    Discretes should be relatively easy to substitute. It's the hybrid
    modules, eg STKxxxx, that are sometimes obsolete.
    Can you remember the NEC number? Note that Japanese transistors often
    drop the leading "2S" in the part number. For example, a 2SCxxxx part
    may be stamped with Cxxxx.
    - Franc Zabkar
  15. Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.pc-homebuilt,comp.sys.ibm.pc.hardware.misc,comp.sys.ibm.pc.hardware.video (More info?)
    I would not fool around with the monitor's circuit boards. Especially, the
    unit was purchased for $22. Just dump it and get another one form eBay.
    David Wang - Tech Support
    Extreme Node - Blade servers and Linux clusters based on the standard ATX
    form factor
    http://www.extremenode.com
    "Arno Wagner" <me@privacy.net> wrote in message
    news:2r5r44F16kn24U1@uni-berlin.de...
    got a
    It
    the
    it to
    turn-on,
    should I
    > be done properly.
    > Arno
Graphics Cards Hardware Monitors Homebuilt Graphics
