G
Guest
Guest
Archived from groups: comp.security.firewalls (More info?)
My company has just bought a Zywall 30w, which is plugged into a Cisco
837 ADSL router (which is permanently on) through the WAN port, and then
into a switch from the LAN port. All the addresses on the network are
static on a range of 80.x.x.x with a subnet 255.255.255.192
The router is set as the default gateway on 80.x.x.129 on all the PCs.
I've plugged the 30W in, set the encapsulation to Ethernet, turned the
firewall off in SMT, turned off DHCP on the firewall, and tried entering
various addresses as the WAN and LAN IPs. Whatever I do, I can't see out
of the internal network, even to ping something. Zyxel are no help, so
can anyone suggest what addresses I should be using, or what else I
could try just to get the basic internet access working - I'll sort out
the firewall later!
Why can't I just allocate one of my 'spare' static IPs to both LAN and
WAN ports, as the only thing that Demon check is hostname, login and
password which are all supplied by the router before anything reaches
the firewall?
Oh, yes, the ISP is Demon Internet (Thus), who supplied the router.
TIA for any help.
Jasper
the firewall later!
the firewall?
TIA for any help.
Jasper
