G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati,microsoft.public.windowsxp.hardware,microsoft.public.windowsxp.video,alt.os.windows-xp,comp.sys.ibm.pc.hardware.video (More info?)
I have an ATI Radeon 9800 Pro which has been having problems with the
TV-Out capability. ATI has been less than helpful in trying to help
me resolve them. The issue is the quality of the picture is very
poor. Before anyone interjects and says TV-Out quality is normally
poor, I am aware of that, but it is even worse than it should be.
Specifically what I am seeing is as follows: While the PC boots the
TV-Out quality is as expected. I can clearly see my POST and early
boot-up sequence. The Windows XP splash screen looks perfect, than
right when the scrolling progress indicator on the splash screen
pauses (mine always pauses for a split second after being up for a few
seconds.) the picture becomes very snowy. Shortly thereafter the
picture goes away entirely. Now this happens whether I have any ATI
specific driver loaded or not. (That is to say, even with no ATI or
Windows drivers for the 9800 Pro loaded, I get TV-Out up to this
point.) If I do have the latest 9800 Pro drivers loaded, I must
enable TV-Out from the driver control panel, however the quality is
still very poor as mentioned above. I had a 9700 Pro in the past
which seemed to work fine (except it would overheat so ATI sent me a
new 9800 Pro replacement)
Additionally, after messing around with it for a while, I decided to
re-install Windows from scratch. Everything worked perfectly for a
few weeks (including TV-
Out) but then just today, the problem came back. There is nothing I
can put my finger on in terms of software I have installed, or driver
updates I may have gotten to cause the issue. I have obviously
re-installed all the video drivers to no avail. I have also
un-installed anything I could think of since It last worked. No dice.
Tried restoring to a restore point where I know it worked, still no
help.
If anyone knows of any issues, has seen this problem before, or has
any info on how I can proceed, I would appreciate it very much. I am
a software engineer, so no need to dumb it down for me.
I am currently running SP2 with all the latest updates. However as
mentioned before, I have not updated Windows in the recent past so it
did work with SP2 installed previously.
help.
