Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
Recently, I have been having problems with starting up my PC after is
has been turned off for me the 1 hour. The only error I receive is
Invalid boot diskette insert boot diskette in A: sometimes. If I take
and turn if off disconnect the drive and power and the plug it back in
it starts up fine. I have ran WD DATA Lifeguard on the drives nothing
shows. I have tried multiple drives same things. Have wrote full O's to
the drive reinstalled just OS and same thing occurs. Sometime I get it
started after about two or three attempts.
This morning what it did after about 30 minutes is it rebooted itself
then I got the Invalid Boot Diskette message. Did my power off and
unplugged and plugged back in start up fine.
If your machine is a gateway socket A athlon, there was an issue like that
with these early on that is resolved by updating the bios.
"RDBrimmer" <ronb21@att.net> wrote in message
news:apy8d.491305$OB3.162818@bgtnsc05-news.ops.worldnet.att.net...
> Recently, I have been having problems with starting up my PC after is has
> been turned off for me the 1 hour. The only error I receive is Invalid
> boot diskette insert boot diskette in A: sometimes. If I take and turn if
> off disconnect the drive and power and the plug it back in it starts up
> fine. I have ran WD DATA Lifeguard on the drives nothing shows. I have
> tried multiple drives same things. Have wrote full O's to the drive
> reinstalled just OS and same thing occurs. Sometime I get it started after
> This morning what it did after about 30 minutes is it rebooted itself then
> I got the Invalid Boot Diskette message. Did my power off and unplugged
> Any ideas or suggestions?
> Thanks,
> Ron
>>Thanks,
>>Ron
System Model
Windows XP Professional Service Pack 2 (build 2600)
Gateway E-4600 4000762
Processor a Main Circuit Board b
1.90 gigahertz Intel Pentium 4
8 kilobyte primary memory cache
256 kilobyte secondary memory cache
Board: Intel Corporation D850GB AAA49507-904
Serial Number: IMGB14421406
Bus Clock: 100 megahertz
BIOS: Intel Corp. GB85010A.15A.0046.P13.0108201551 08/20/2001
My guess would be a failing power supply.
> Thanks,
> Ron
I had a lower version of that model (1.4Ghz) and my boot and reboot issues
were faulty ram. Try memtest86 (http://www.memtest86.com/), it'll test the
ram for problems.
Smith
news:b%z8d.491751$OB3.485171@bgtnsc05-news.ops.worldnet.att.net...
>> that with these early on that is resolved by updating the bios.
>>>Thanks,
>>>Ron
> System Model
