Archived from groups: comp.sys.ibm.pc.hardware.video (
More info?)
GS Wilder wrote:
> It's really a strange problem.
> I am pretty sure the lines were not there when I installed it this
> afternoon. I didn't notice it until several hours later.
> I have tried on 2 different PCs (both with nVidia card). Same problem.
> Downloaded latest nvidia driver. no help
> The lines are really starting to bug me. I do not want to spend almost
> $2k for something like this. But I need to know folks opinion. Bad
> monitor or is this the way they are supposed to look?
If you don't have Powerstrip you might want to download it
<http://entechtaiwan.net/util/ps.shtm> and play with the resolution
adjustment--it sounds like your video board might be running at a
horizontal resolution just a little tiny bit different from the native
resolution of the display, causing artifacts to appear in the form of the
vertical lines you describe. Or it could just be that you have a defective
monitor.
> Thanks....
> Bob Niland <email4rjn@yahoo.com> wrote:
>>> Gregory <greg.wilder@insightbb.com> wrote:
>>> Just purchased a 24" Samsung 243T LCD monitor.
>>> There are 2 faint vertical lines running up and
>>> down right in the middle of the display.
>>You might create some wallpaper files, each at
>>full-res and of a single color, such as:
>>Load each in turn as the wallpaper, with all other
>>stuff minimized (or use an image viewer with full-
>>screen mode), and see if the problem is specific to
>>a single color drive. If you have a jeweler's loupe,
>>examine the affected color triads.
>>With all-white.bmp engaged, you should see distinct
>>R-G-B triads in black boxes. If you see anything
>>else, it might be an artifact of how the panel was
>>fabricated. If you see the absence of a color primary,
>>suspect a defective panel (or graphics card).
>>To rule out the graphics card, create 640x480 subsets
>>of the bmps, wallpaper them, and let the monitor upscale
>>them to fill the screen.
>>> I thought I remember earlier generation LCD's
>>> that had some kind of "wire" that
>>> ran behind the display and could be seen.
>>Prior to the deployment of FABs that could handle full-
>>size LCD substrates, some early "large" LCDs might have
>>been tiled from smaller panels, in TV "window wall"
>>fashion, and these would have visible join lines.
>>There's no excuse for that in a contemporary LCD.
>>I'm no expert on this, but I don't know of any other
>>reason for such lines.
>>On aperture-grill CRTs (Trinitrons), of course, two
>>horizontal lines are common, representing the shadow
>>of the tension band wires that stablize the thousand
>>or so vertical grill wires.
--John
Reply to jclarke at ae tee tee global dot net
(was jclarke at eye bee em dot net)
