Help: Getting Graphics Card to Work
Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
I've just spent three hours trying to get my video card working.
I had a system put together minus a graphics card because I wanted to
install a Jetway Radeon 9550(95LXAD256C) card that I have.
Unfortunately, I'm having problems. With the card plugged into the AGP
slot, when I get one beep, followed by three quick beeps when I power
up, and there is no signal whatsoever going to the display.
Since I get no signal to the monitor at all, my options seem limited.
When the system was built, a Diamond Stealth II G460 8MB was used, and
then taken out before the system was given to me.
The motherboard is an Asus CUV4X and all of the chips on the video card
itself are hard-wired.(For what it's worth, I see a bank of 8 dip
switches on the motherboard. All positioned upwards, except #4.)
I know nothing about IRQ conflicts, and would be nervous about messing
with them since the guy who put the system together knew what he was
doing, and I don't.
Any advice would be greatly appreciated.
Thanks a lot.
Darren Harris
Staten Island, New York.
24 answers Last reply
More about help graphics card work
  1. Archived from groups: comp.sys.ibm.pc.hardware.video,rec.video.desktop (More info?)
    I think there is a good chance the video card is not seated properly.
    It's likely not pushed in all the way. Check carefully and see if the video
    card is all the way in the socket.
    Bob Noble
    www.sonic.net/bnoble
    <Searcher7@mail.con2.com> wrote in message
    news:1103435457.777971.242980@f14g2000cwb.googlegroups.com...
    > doing, and I don't.
    > Thanks a lot.
    > Darren Harris
  2. Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
    1 beep, 3 beeps, 1 beep is a code for bad
    or invalid memory. You might want to check
    the memory to make sure that is good and
    fits this motherboard.
    John
  3. Archived from groups: comp.sys.ibm.pc.hardware.video,rec.video.desktop (More info?)
    My first instinct would be to try whipping out that MB manual and
    looking up what the beep code(s) means...
    >doing, and I don't.
    >Thanks a lot.
    >Darren Harris
  4. Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
    to
    AGP
    power
    limited.
    and
    card
    messing
    > >doing, and I don't.
    > >Thanks a lot.
    > >Darren Harris
  5. Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
    to
    AGP
    power
    limited.
    and
    card
    messing
    > >doing, and I don't.
    > >Thanks a lot.
    > >Darren Harris
  6. Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
    This is my 8th time attempting to post this since Google screwed up
    everything.
    I know the video card is seated correctly, and the beeps indicate what
    John said.
    The motherboard supports AGP/AGP Pro 4X. And the video card's
    documentation says that it supports AGP Universal Bus 8X.
    I just noticed that the three 4-pin male connectors(white, green, and
    black) on the motherboard to the left of PCI slots 1 & 2. Page 14 in
    the motherboard's manual says they are "AUX", "Video", and "CD". It
    obviously slipped out of the CD ROM connection, so I put it
    back(hopefully the right way).
    Like I mentioned, all chips on the card are hardwired, so no chips can
    be added or taken away. And the card worked in a different computer.
    Any more ideas?
    Thanks a lot.
    Darren Harris
    to
    AGP
    power
    limited.
    and
    card
    messing
    > >doing, and I don't.
    > >Thanks a lot.
    > >Darren Harris
  7. Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
    everything.
    John said.
    Any more ideas?
    Thanks a lot.
    Darren Harris
    to
    AGP
    power
    limited.
    and
    card
    messing
    > >doing, and I don't.
    > >Thanks a lot.
    > >Darren Harris
  8. Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
    everything.
    John said.
    Any more ideas?
    Thanks a lot.
    Darren Harris
    to
    AGP
    power
    limited.
    and
    card
    messing
    > >doing, and I don't.
    > >Thanks a lot.
    > >Darren Harris
  9. Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
    everything.
    John said.
    Any more ideas?
    Thanks a lot.
    Darren Harris
    to
    AGP
    power
    limited.
    and
    card
    messing
    > >doing, and I don't.
    > >Thanks a lot.
    > >Darren Harris
  10. Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
    to
    AGP
    power
    limited.
    and
    card
    messing
    > >doing, and I don't.
    > >Thanks a lot.
    > >Darren Harris
  11. Archived from groups: comp.sys.ibm.pc.hardware.video,rec.video.desktop (More info?)
    A better suggestion would be to have the person who put the systems
    together give you the awnser. Or if local take it to him.
    >to
    >AGP
    >power
    >limited.
    >and
    >card
    >messing
    >> >doing, and I don't.
    >> >Thanks a lot.
    >> >Darren Harris
  12. Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
    I was just told that it is common that a video card can be incompatable
    with one's display, and that manufacturers intentionally leave this
    fact out of the manuals. Is this true?
    I tried it with a Dell P990, and an IBM 7097-593.
    Thanks.
    Darren Harris
  13. Archived from groups: rec.video.desktop (More info?)
    In article <1103771108.701460.221860@z14g2000cwz.googlegroups.com>,
    No. It's possible your card could be capable of higher resolutions and/or
    scan rates than your monitor but then all you have to do is set things
    accordingly. Certainly, people do not /intentionally/ leave things out of
    manuals - that's just crazy.
    Iain Laskey
    Practical PC Online www.practicalpc.co.uk
  14. Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
    > No.
    > The beep code indicates that the problem is with the computer and not
    > the monitor. Did you look up the beep code as suggested?
    As I mentioned the beeps indicate what John said. The problem is with
    the graphics card.(Which actually doesn't say much). Specifically A)
    Bad video ram or B) No card installed. Now since the card works in a
    different system, it can't be either of those two options. I'm thinking
    that there is a compatibility issue that one won't find just by reading
    the motherboard and video card manuals.
    Anyway, there is obviously no answer to this problem.
    Thanks.
    Darren Harris
  15. Archived from groups: comp.sys.ibm.pc.hardware.video,rec.video.desktop (More info?)
    No.
    Gary L.
    Reply to the newsgroup only
  16. Archived from groups: comp.sys.ibm.pc.hardware.video,rec.video.desktop (More info?)
    On 23 Dec 2004 14:46:21 -0800, Searcher7@mail.con2.com wrote:
    >> No.
    >Thanks.
    >Darren Harris
    There may be.
    If the slot the card is in isn't connecting to all of its traces on
    thre MOBO, the card may not work, while it will work in another
    computer.
    Bill Funk
    Change "g" to "a"
  17. Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
    > There may be.
    > computer.
    I have no idea how all of the connections cannot be made, since I have
    another video card that does work perfectly in this system, and the
    Jetway video card that I can't get to work in it works perfectly in
    another system.
    So the problem stems from this specific system *with* this specific
    video card.
    Thanks.
    Darren Harris
  18. Archived from groups: comp.sys.ibm.pc.hardware.video,rec.video.desktop (More info?)
    On 24 Dec 2004 12:13:07 -0800, Searcher7@mail.con2.com wrote:
    >> There may be.
    >> computer.
    >another system.
    Sorry, I misunderstood you to say the card worked in another syste.
    Maybe another card is in order.
    >video card.
    >Thanks.
    >Darren Harris
    Bill Funk
    Change "g" to "a"
  19. Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
    Yes. The card did work in another system.
    Anyway, I'll have to get another video card, and cross my fingers.
    Thanks.
    Darren Harris
  20. Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
    I don't know if this will help any. Does your video card have its own
    plug for the monitor?
    I just installed a new card in my nephew's computer, and I didn't
    realize the cards had their own plug. So, I kept plugging the monitor
    into the regular plug. Everytime the card was in, the monitor got no
    signal. Take the card out - just fine. And repeat.
    I finally noticed the card had its own slot, plugged it, and everything
    was great. I spent over an hour wading through the FAQs on company's
    website and searching the archives here. Never did see anything that
    covered the issue.
  21. Archived from groups: comp.sys.ibm.pc.hardware.video,rec.video.desktop (More info?)
    >covered the issue.
    That's interesting!
    Didn't the new card come with any documentation that included
    something along he line of, "Plug monitor cable into the port on the
    back of the card"?
    I can see the confusion; if the computer has the video *on the mobo*,
    and the user has no experience in this, that could be an interesting
    thing!
    Bill Funk
    Change "g" to "a"
  22. Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
    It was very minor, so I skipped over it.
    It said, "Reconnect any devices that you detached during installation
    and then connect the monitor's video cable to your new card.
    I read it as - reconnect all cords, blah, blah, blah. That's what I
    get for skimming. It wasn't until I had it working that I found that
    line in there. And I was only looking because I was sure it wasn't
    there.
    I am still pretty surprised that there was no mention of it in the
    FAQs.
  23. Archived from groups: comp.sys.ibm.pc.hardware.video,rec.video.desktop (More info?)
    >there.
    Yup, that'll do it. :-)
    >FAQs.
    Bill Funk
    Change "g" to "a"
  24. Archived from groups: comp.sys.ibm.pc.hardware.video, rec.video.desktop (More info?)
    I confused, and not sure if I understood that experience.
    I inserted the card into the AGP port and then plugged the monitor
    cable into the card's 15-pin female connector. The card has S-Video and
    DVI outputs, and came with a black cable(I believe was for S-Video)
    that I didn't bother taking out of the package, but that is all.
    Anyway took a little monetary loss and gave it back to the guy I won it
    from(on Ebay) at a cost lower than I won it for.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=5147190046
    Thanks.
    Darren Harris
Graphics Cards Video Graphics
