G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.video (More info?)
The image on my CRT monitor recently started twitching intermittently. It
happens mostly when I first turn it on and seems to settle down after a
while. One thing that's changed is the cpu is now on top of the desk next
to the monitor with about six inches between them (used to be on the floor).
I don't think this is the problem though, as there are many monitors where I
work setup right next to cpus without image problems. Also, if the
interference were coming from the cpu wouldn't the image jitter be
continuous instead of going away after a while? Could my video card be the
culprit?
culprit?
