New monitor cable, problem with picture
G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.video (More info?)
Hello group,
I'm having a problem and I don't really know how to describe it but
I'll give it a shot:
My monitor cable was bad (some of the pins broke out) so I bought a new
one. I plugged it in and the picture is worse than it was with the
broken cable. The picture looks like there is a "drop shadow" behind
everything. It's as if everything has a copy of itself about 5 pixels
down and 5 pixles to the right. I'm not sure what that's called and I
hope I explained it correctly.
Do I need to just go buy another monitor and have a trial and error
session? I downloaded the newest video card drivers, messed with the
resolution and refresh rates but nothing fixed it.
What am I missing?
G
Guest
Guest
<soxtrot@gmail.com> wrote in message
news:1125253669.427984.284010@z14g2000cwz.googlegroups.com...
> Hello group,
> What am I missing?
You appear to be seeing the classic symptoms of a cheap monitor
cable. The impedance isn't well controlled, so you are getting
reflections. I'd suggest buying a better cable. Make sure the
new one is a nice thick cable (no guarantee, but a good indicator)
with a ferrite bead (the black lump around the cable).
Good luck
Dan (Woj...) [dmaster](no space)[at](no space)[lucent](no space)[dot](no
space)[com]
"One more sun comes sliding down the sky / One more shadow leans against the wall
The world begins to disappear / The worst things come from inside here
And all the king's men reappear / For an eggman, on and off the wall
Who'll never be together again"
G
Guest
Guest
"Dan Wojciechowski" <too.much@spam.com> wrote in message
news:dev3jq$1tj@netnews.net.lucent.com...
> > What am I missing?
"Nice thick cable" may be a good indicator; the presence
or absence of a ferrite on the cable has absolutely nothing to
do with this problem, except to whatever extent it may (or
may not) indicate a "better cable." You can certainly make
a very good cable assembly with no ferrite at all.
Bob M.
