Monitor Wont Display anything
G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.video (More info?)
Alright no huge techical words i am only 16 years old :oops: :lol:
But anyways Okay i was working on my computer today, got rid of a
virus, it asked to restart, so i did so, only to find out that
something screwed up and it kept restarting the computer, went to
plug in my floppy and all (at the time i didnt have it hooked in) and
then it wouldent display anything on the monitor, so i tried unhooking
everything like at my last job they told me to do it when the monitor
wouldent give you a picture so i did so, spent like 3 hours on it it
still aint working and was wondering if anyone would please help a
little 16 year old nerd out :lol: :lol: :lol:
Thanks dudes,
Airforce9999
@ http://www.tcwoonline.com
G
Guest
Guest
"Airforce9999" <Einstein196@gmail-dot-com.no-spam.invalid> wrote in message news:zQMVe.1688$vo5.534@fe01.news.easynews.com...
> Thanks dudes,
> Airforce9999
Not really a lot of information to work with here, but assuming you get no output to the monitor at all, it sounds like the Virus
has somehow messed up your BIOS settings.
Try resetting it - usually theres a 2-pin jumper on a 3-pin header near the BIOS chip that needs to be moved across to reset the
settings. Don't forget to move it back to the original position before attempting to reboot.
After that you need to run the virus check again.
HTH
Brian
There are no underscores in my email address.
G
Guest
Guest
Sick of viruses?
http://www.mepis.org/
If you're *really* a nerd, you'll try it out. 8)
G
Guest
Guest
The very first thing you want to do is verify whether or not
it is, in fact, the monitor or if its the PC (I'm betting on the
latter - it would be a huge coincidence if the monitor just
happened to choose this point in time to die). Swap in
a different monitor, and try the monitor you have on another
PC.
If you can't do that, it IS almost certainly the PC, or more
specifically something which has been screwed up in your
BIOS or other configuration.
Bob M.
G
Guest
Guest
:lol: I dont know what that site even is, as for the monitor problem
well before that gayness happened the computer had a very bad virus,
that Panda found, once deleted it asked for restart, and boy o boy it
restarted, about 100 times on its own when ever you tried to log in,
it scr*ewed up and instead of loggin in it would restart, but what i
saw from when i tried it it gave the most famous "Blue Screen o'
Death" :lol: So it might be a hardware problem but it happened to
another computer (The virus did) and now i am formating that one
these are my dads and i am having no problem with mine so i dont know
what is going on with him and of corse he says he didnt do/go
anywhere/anything on it :roll: :roll: :lol: :lol: :lol:
