Tom's Hardware > Forum > Graphic & Displays > Nvidia > Geforce FX 5600 XT and DirectX9.0b - Problems when running..
Forum Graphic & Displays : Nvidia - Geforce FX 5600 XT and DirectX9.0b - Problems when running..
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Anyone else having problems with this card and the latest NVidia ForceWare
drivers (56.72)??
The card won't render anything that uses DirectX (Direct 3D Acceleration).
When I run the DXDiag program the DirectDraw Acceleration works fine, but
the Direct 3D Acceleration bombs and returns errors for all DirectX 7, 8
and 9 tests.
I can't get any of my 3D games (Quake, UT, SpellForce) to run at all!!
Anyone else had similar problems, any advice would be helpful
Thanks
My Spec:
Windows 2000 (SP4)
Geforce FX 5600 XT - 128Mb
AMD Athlon 1.2Mhz
512 Ram
ABit KG7 Mainboard
DirectX 9.0b
Forceware drivers v56.72
Sponsored Links
nitefoll <nitefoll@darkfall.demon.co.uk> wrote in message news:<fpt77010cjs2nhq68fo2f8pr4ts6492mc2@4ax.com>...
> drivers (56.72)??
> and 9 tests.
> Thanks
> My Spec:
> Windows 2000 (SP4)
> AMD Athlon 1.2Mhz
> 512 Ram
> ABit KG7 Mainboard
> DirectX 9.0b
You Re-installed DirectX yet?
Reply to Anonymous
There are 1276 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
