G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Recently installed a Gainward 5900 Ultra. I have an creative audigy 2 sound
card. Worked ok for a few days. Then in the middle of playing UT 2003 sound went
out. Now I have no sound at all on the computer.
I wiped creative drivers and reinstalled. Updated to the latest. Using the 5672
Nvida driver for the 5900.
Creative tech support want me to update bios on mother board. They also
suggested that the wiring inside my box might be interfering with the Audigy
(sounds far-fetched to me). Don't want to start fiddling unless I have a better
understanding of what might be the problem
My question is: Is it somehow possible that the Audigy board got damaged by the
heat or some other operation of the 5900? I should add that I'm using the 1394
on the Audigy to run some external firewire drives and there is no problem
there. Also the audigy board is in the PCI slot next to the last away from the
5900 so it is not physically close.
Other than this (perhaps far-fetched idea) does anyone have a clue what might be
the problem?
By the way I have an ASUS P4-T Mobo and a 450 watt power supply. Using XP pro.
Sorry if this is a more appropriate question for a sound card group but I
haven't found an active Creative sound card newsgroup.
Thanks,
Perrera
the problem?
Thanks,
Perrera
