Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
I have a Gateway Performance 800 with 800MHz P3 inside....'and a problem
maybe.
Every time I press the button on the base to turn the machine ON, the light
on the front comes on and it makes the usual sounds, but after 2 or 3
seconds, it switches itself OFF.
It just keeps doing this until I take the plug out at the back for app., 10
seconds and re-insert it.
Then it does the same routine as described all over again.
I'd check the power supply.
Bob
"Eos" <FreeSoft@(SkipTheBrakets)Tiscali.co.uk> wrote in message
news:yBsrd.61048$F7.51222@fe1.news.blueyonder.co.uk...
> maybe.
light
> Can anyone help me with this?
> Thanks.
> Geo.
Weird! It all seems to be working fine now (I hope!), but all I did was to
follow the wires from the switch on the front of the base to where it plugs
into the mobo....'then I disconnected this plug for a few seconds and
re-connected it.
The PC fired up right away! Anyone have any explanations for me as to what
might have caused all this?
Is it significant in anyway? Would this indicate a fault?
Thanks.
Geo.
"Bob" <bobdawn1@verizon.net> wrote in message
news:6Ysrd.4143$zK1.2719@trndny05...
> Bob
One explanation is that plugs come loose....it's a fact of life :-)
ANother explanation is that you are just having some moments of luck right
now, and the power supply is still faulty. I have seen this happen in the
past - computer randomly rebooting itself, booting up for an hour and then
shutting down, etc. So I wouldn't say you are totally out of the woods
yet
news:aWtrd.61107$F7.50827@fe1.news.blueyonder.co.uk...
plugs
> re-connected it.
> Thanks.
> Geo.
> > Bob
Eos (FreeSoft@(SkipTheBrakets)Tiscali.co.uk) wrote:
: I have a Gateway Performance 800 with 800MHz P3 inside....'and a problem
: maybe.
: Every time I press the button on the base to turn the machine ON, the light
: on the front comes on and it makes the usual sounds, but after 2 or 3
: seconds, it switches itself OFF.
: It just keeps doing this until I take the plug out at the back for app., 10
: seconds and re-insert it.
: Then it does the same routine as described all over again.
: Can anyone help me with this?
: Thanks.
: Geo.
Check for leaking capacitors, such as the photo included in this article:
