G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Hi All,
I have a Visiontek Geforce 3 Ti500 that has performed wonderfully over
the years. However, now the cooling fan 'grumbles' for about 3-4
minutes at the start of each day. Then, it seems like it 'realigns',
the noise goes away, and I can hear the fan spin up to a higher RPM.
But I figure the fan is on its last legs.
I've purchased an Iceberq 4 replacement fan, but I'd like to
understand the replacement process a lil more before I jump in. Must I
remove the heatsink, along with the fan? Can I just remove the fan
from the heatsink easily? If I remove both, how do I proceed from
there. Obviously, I need to attach the new fan to the heatsink, but do
I need to remove the heatsink in order to do this? The Iceberq kit
contains a compound of sort, but is this glue, or just thermal?
Thanks for your assistance!!
mike
Hi All,
mike
