Tom's Hardware > Forum > Systems > Gateway2000 > Task Bar Problem
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
When I press ctrl-alt-del I get the task bar window less the tabs at the
top! I can switch to Applications, Processes, etc. I have scanned for
viruses - nothing; run spybot - nothing; Ad-Aware - nothing. Can anyone
help?
Sponsored Links
Try logging on as ADMINISTRATOR. If I understand your comment, it looks
like your priveledges are denied.
Logging on as Administrator should take care or that.
Reply to Ed
>help?
Are you referring to the Task Manager window?
If so, double-click in the area at the top of the windows. It would be just
above the bars that say Image Name, User Name, Task, Status, User, CPU Status,
etc (depending on what tab contents are actually displayed).
That should bring the tabs back, as well as the File, Options, etc, menus.
Reply to Anonymous
There are 1338 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
