Graphics Problems/Artifacts
Gaffer
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Hello,
I originally had a Geforece Ti4200 8X, but I started getting a lot of
graphics problems with certain games (high spec ones) so I decided to buy a
new card and got a Geforce FX5700. It's now much better but I still very
have the problems (although no where near as bad) with certain game and want
to know what is causing this. Could it be my screen refresh rate, damaged
AGP slot or something else. It's driving me crazy. Could someone give me
advice and ask me some settings to check that might help me on this?
Thanks
_____
Gaffer
Hello,
Thanks
_____
Gaffer
5
answers
Last reply
More about graphics problems artifacts
Check bios and setup Agp aperture to 256mb .Make sure its not set too low
like 32 mb . It that dont help it could be the power supply to the card .
Theres other stuff it can be too but those are too possiblities u can try.
"Gaffer" <gafferNoSpam@ntlworld.com> wrote in message
news:1r9rc.209$3T.111@newsfe2-gui.server.ntli.net...
> Hello,
a
want
> Thanks
> _____
> Gaffer
It maybe to do with the agp 8 x . Check that bios has enabled 8 x agp.
> Hello,
a
want
> Thanks
> _____
> Gaffer
Ok, I'll check all that. Just keep firing more suggestions away and I'll
check them all :-)
Thanks,
_____
Gaffer
"wired and confused" <johnsongerry@comcast.net> wrote in message
news:%ecrc.86349$536.14430429@attbi_s03...
> > Hello,
buy
> a
> want
damaged
> > Thanks
> > _____
> > Gaffer
Have you thought to check on the Temp of your mainboard? Maybe your
northbridge is too hot, could also be your cpu getting too hot. -
"live and let live" <vodkadrinkers@t-online.de> wrote in message
news:c8l4qu$tit$04$1@news.t-online.com...
I only seem to get the texture problems when I'm playing a game that has big
spacious areas, if you know what I mean. If I am playing something like Vice
City or Manhunt then I will get the problems more because they are in
wide-open areas and my card can't cope with the draw-distance, even though
it should be well capable of doing so. It's almost as if the card isn't
being used to it's full potential.
_____
Gaffer
Related Resources
Nvidia
Games
Graphics
Related Resources
- Nvidia graphics freeze
- Problems with graphics and power
- BFG 6600 GT OC: Why are the graphics flickering?
- Nvidia Ti4200 problem
- NVidia GTX 560 TI problems.
- I've searched all over... Nvidia problem.
- My New Graphics Card, what should it be?
- NVIDIA GeForce 8800 GT Problems
- NVidia GeForce 5200 fx problems
- Nvidia 250gts problems
- NVidia 6 series graphics card
- Help with Nvidia Geforce FX5700 Ultra
- Problems with Windows 7 64-bit and nVidia drivers
- New Graphics Card Installation problems
- Nvidia GeForce FX 5200 Graphics Card replacement
