no sound running nview in dualview mode
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Hi,
I've recently hooked up the audio/video-out of my nforce2 mobo to my
TV set... now running picture on monitor and second display fine.
Odd thing is, when I have nview set to 'clone' mode, I'm getting
picture and sound on my TV. As soon as I switch to 'dualview' mode
(mainly so I can set the TV output to a different res/refresh rate), I
seem to lose all sound output.
Got to be missing something daft here... any thoughts folks?
3 answers Last reply
More about sound running nview dualview mode
  1. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    "orbis" <ebrius33@yahoo.co.uk> wrote in message
    news:1bf87bfc.0406150646.2af0e7c2@posting.google.com...
    > Hi,
    Not sure how you managed to get sound from the TV in clone mode - the TV out
    socket on nVidia cards are video only, no audio. Audio output is from the
    sound card in the PC. I have my TV out hooked up to a svideo-composite
    adapter that came with the card which then connects to a RCA-SCART lead, and
    3.5mm-2xRCA from my sound card speaker jack to the 2 audio RCA connectors on
    the SCART lead.
    Dan
  2. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    > the SCART lead.
    > Dan
    Sorry Dan, I didn't explain that very well... My TV-out is via a cable
    with both composite video-out and 2xRCA (using an adapter to connect to
    the standard 3.5mm line-out jack on my PC).
    As it happens, on the other end of this cable is a Trust 120V wireless
    transmitter, the revceiver of which is in another room plugged into my
    TV. I kind of assumed that the bits and pieces between the PC and TV
    were pretty incidental, given that I get both a good picture and clear
    sound in 'clone' mode. But maybe the physical setup's more relevant than
    I thought?
    I'm running with all nvidia's latest drivers, and to be honest I could
    live without dualview and just use the clone mode, but these little
    niggles bug me more than the showstoppers sometimes... Grr.
  3. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    "Orbis" <orbis@NOSPAM.ebrius.net> wrote in message
    news:_DJzc.69244$B63.24053@doctor.cableinet.net...
    > I thought?
    Do you also have speakers running in that setup, with a 3.5mm splitter? Or
    is audio exclusively sent to the TV?
    I run my setup with dualview (monitor + tv) and have never had an audio
    problem. I do however use a soundcard rather than onboard sound, I suppose
    it is possible that something is interfering with the motherboard drivers
    and disabling sound. What motherboard do you have? What nVidia drivers and
    motherboard drivers are you using?
    BTW: I'm running the 56.72 drivers with a GF FX5900XT (and before that a GF4
    Ti4200 in the same setup), on an nForce2 board (Asus A7N8X-X) using the 2.45
    nForce drivers. This is on Windows 2000 Pro SP4.
    Dan
Nvidia TV Graphics
