G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Hi,
Trying to get the DVI connection working on an old GF3 Ti200, and having
major problems. This is on W2K btw.
The symptoms are:
1. If I uninstall all drivers, so I'm just using the basic VGA driver,
then if I plug in the DVI connection only, all is well and it work
perfectly, albeit at low res and colours.
2. If I install the latest Detonator drivers (56.72), then if I boot
with both the DVI and analogue connections connected, then it defaults
to analogue from boot and nothing comes out the DVI.
3. Again with the drivers installed, if I disconnect the analogue
connection then at boot it outputs via DVI. I get the POST screen, plus
the main W2K loading screen on the DVI connection, but as soon as it
switches modes and brings up the logon prompt, it switches back to
analogue, even with nothing connected to it, and I have to connect up
the analogue port to continue. This is with all resolutions and refresh
rates btw.
No 3 is the real puzzler. Once I'm into Windows after reconnecting the
analogue port, there is no mention anywhere in the display settings
(standard or NVidia's) of a DVI port or digital connection of any kind.
I'm wondering if the latest drivers are somehow screwed for the old GF3
cards, and I should try an older set. If so, does anyone have any ideas
which would be the best to use and where to find them?
Getting a bit desperate now, any advice gratefully received.
Toby
Hi,
The symptoms are:
rates btw.
Toby
