System Power
HHD Led will not turn off when system is turned off.
I have checked and doubled check all wirings
have checked the sleep settings, and the Bios
need help, thanks.
1 answer Last reply
More about system power
  1. Try updating the BIOS(even if it has last update),once ran,power off,remove
    battery,move board CMOS jumper pin from 1-2 to 2-3 position for .30 seconds
    or so,then back to 1-2 position,replace battery,power up.You'll need to reset
    basic BIOS configurations,date,time,etc,save and exit BIOS. You're problem isn't
    a windows issue, it's hardware.
    when clear Cmos takeoff power from AC
LED Monitor Power Windows 7
