dvi-i vs anolog output to drive crt monitor - quality
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Well here is the deal.
I have 1 crt monitor but when that fades out would like to replace
with lcd. Ultimately having 2 monitors would be nice. Uses are
home video editing, digital photographs 2d applications and would like
to experience nice game on single monitor. Also would like to run a
rudimentary CAD application. Very important ot me is having very crisp
letters in 2-d applications (you know word processing) .
I would like a card that can support dual dvi-i interface.
But most cards have 1 dvi-i and 1 analog vga output for the crt
monitor.
THe question is how will the crt monitor look if hooked directly to
the dvi-i interface via an adaptor that makes use of the last 4 pins
in the dvi-i plug. Does the adapter convert the signal as well as a
dedicated vga output that comes on video cards that support have
1dvi-i and 1 vga output.
THis is an issue because as I said ulimately I would like to have 2
monitors hooked to the 2 dvi-i outputs on a card.
Also Suggestions for card in 180-250 dollar range nvidia or otherwise.
Thanks
14 answers Last reply
More about anolog output drive monitor quality
  1. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    > monitor.
    DVI-I has the exact same analog signals present as VGA. The adapter just
    carries the signal to the right pins. If youi google "dvi-i pinout" and
    "vga pinout" you'll find diagrams of both right quick.
    > Thanks
    There are several dual-dvi GeforceFX 5700 boards in that price range. If
    you're willing to sacrifice DirectX acceleration to get text quality, there
    are a couple of Matrox models as well.
    --John
    Reply to jclarke at ae tee tee global dot net
    (was jclarke at eye bee em dot net)
  2. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    On Mon, 19 Jul 2004 23:19:21 -0400, "J. Clarke"
    Is it right to assume the text quality would be the same when hooking
    up a dvi capable lcd monitor to the dvi-i output?
    Are you just refering to the text output on the anolog portion of the
    dvi-i connector when hooking up the Crt monitor to that?
    Thanks
  3. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    > in the dvi-i plug.
    It will look exactly the same. The DVI socket contains a normal VGA signal -
    the adaptor simply makes the connection fit.
    No need - it's already a standard VGA signal. The digital DVI part, is
    carried on seperate pins.
    Be sure to buy a card with dual DVI outputs.
  4. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    On Tue, 20 Jul 2004 08:56:03 +0100, "Nom" <Nom@Somewhere.Somewhere>
    >> in the dvi-i plug.
    Thanks for the help.
    So the quality of the anolog ouput , is a function of that produced by
    the quality of the card's production of analog, and not the fact there
    is a dvi-i connector in the way of getting it to the crt monitor via
    an adaptor that just gets the 4 pins correctly spaced to the crt
    monitor cable.
    But this does not mean that a graphics card with 2 dvi-i will have as
    high a quality analog signal as a card that has 1 dvi-i and 1 vga
    connector. In fact less good parts could be present on the video card
    for that analog signal, because they may assume it will get hooked to
    dvi capable lcd monitor.
    Also , why should one assume that a video card with 1 dvi-i ouput and
    1 vga output will port as high a quality analog signal throught the
    dvi-i output terminal versus the vidoe card's vga output terminal.
    Thoughts? Anyone test this?
    Bu
  5. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    >>> in the dvi-i plug.
    >> signal - the adaptor simply makes the connection fit.
    >> is carried on seperate pins.
    > monitor cable.
    Spot on.
    You're putting far too much thought into this !
    As long as you buy a decent branded card (Gigabyte, MSI, ASUS etc. etc.)
    then the analogue output will be just fine.
  6. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    "steven" <steven@de.d> wrote in message
    news:ag5sf018idfnl53siokdah26v396cos1d0@4ax.com...
    > monitor cable.
    Nvidia normally have two RamDAC [channel].
    First channel - VGA
    2nd channel - DVI
    Let assumed you have two Digital Monitor.
    Signal Degrade
    VGA [anolog] port will need to convert from VGA card - Digital > Anolog >
    Anolog > Digitl > monitor
    No signal degrade
    DVI [digital] port. There no conversion. VGA card - Digital > Digital
    Monitor.
    Do you get the general idea?
    It better to have straight DVI without any conversion. So, if your monitor
    is digital and have DVI port, use it.
    CapFusion,....
  7. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    >>> in the dvi-i plug.
    > monitor cable.
    Or more good parts because it's intended for use in an engineering
    workstation. Bottom line is that the analog video quality is not a
    function of the type of connector used, it's a function of the quality of
    engineering and manufacture that went into the board.
    Ockham's Razor. Assume the simplest hypothesis until proven otherwise.
    > Bu
    --John
  8. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    On Wed, 21 Jul 2004 12:50:04 -0700, "CapFusion"
    >> monitor cable.
    >First channel - VGA
    >2nd channel - DVI
    >Signal Degrade
    >No signal degrade
    >Monitor.
    >CapFusion,....
    Thanks, yes I understand that. That is why I want 2 dvi-i outputs so
    I can eventually hook 2 dvi capable lcd monitor to the card. But
    right now I still have a good CRT monitor. So I want a card that has
    dual dvi-i ouputs but also transmits a very excellent vga signal
    throught the 4 exttra pins that a dvi-i ouput contains for that
    purpose.
    Who makes excellent analog vga signal on a dual dvi-i card?
  9. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    On Thu, 22 Jul 2004 00:49:07 -0400, "J. Clarke"
    >>>> in the dvi-i plug.
    >> monitor cable.
    >> Bu
    Thanks.
    Wonder who makes excellent vga signal in a dual dvi-i ouput card at a
    200-250 dollar price point?
  10. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    >>>>> in the dvi-i plug.
    >>> monitor cable.
    >>> Bu
    > Thanks.
    Matrox has excellent analog signal quality, however they also have no
    DirectX acceleration to speak of. In your price range you're going to have
    to make tradeoffs.
    --John
  11. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    news:cf11g0t58rpedt4ljg28bc3abqpprc4h48@4ax.com...
    > Thanks.
    For general purpose use, any make / model will fine.
    If you just plan on using the DVI port eventually, they just use a DVI to
    VGA conveter for the card with 2 DVI port. No need to spend extra $$$ for
    another card.
    CapFusion,...
  12. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    steven wrote:
    > Thanks.
    Everybody !
    As I've already said, stick to a known-brand card, and the VGA output will
    be just fine.
  13. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    On Tue, 27 Jul 2004 09:02:16 +0100, "Nom" <Nom@Somewhere.Somewhere>
    wrote:
    >steven wrote:
    >> Thanks.
    >Everybody !
    >be just fine.
    Well I posted this over in the alt.comp.periphs.videocars.ati newgroup
    and I got quite a different response from someone.
  14. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    > wrote:
    >> steven wrote:
    >>> Thanks.
    >>> a 200-250 dollar price point?
    >> Everybody !
    Er, and ?
Nvidia DVI Monitors CRT Monitors Graphics
