Tom's Hardware > Forum > General Networking > Firewall > IIS/firewall problem
Forum General Networking : Firewall - IIS/firewall problem
Archived from groups: comp.security.firewalls,microsoft.public.inetserver.iis,microsoft.public.inetserver.iis.security (More info?)
Hi,
I have set up a web site which runs off one of our internal web servers.
Everything works fine when I try to access the site from within our network
but unfortunately it doesn't work at all when I try to access it over the
internet - I get "Cannot find server" error page.
I have configured NAT so that one of our external IP addresses points to the
internal IP address of the server - I know this is working because I have
accessed other services on that server externally. I have also purchased a
domain name and have configured its A record to point to the server's
external IP address. I have configured the host header name in IIS to the
domain name.
I have also opened port 80 on our firewall so that it is open for the source
as the internal LAN web server IP and the destination as "*".
I'm almost totally sure it's a firewall issue because:
1) It works fine internally within our network
2) It still doesn't work when I add the domain name and external IP to my
Hosts file (therefore it won't be a domain issue)
Does anyone have any suggestions as to what the problem could be? Do I only
have to open port 80 for IIS?
TIA.
Sponsored Links
Port 80 is all you need for HTTP traffic, and 443 if you use SSL, I think
your firewall is still the problem. I would check the firewall logs and see
what you find there.
Cheers
Chris
Chris Crowe [IIS MVP]
http://blog.crowe.co.nz
"Jase" <jase@hotmail.com> wrote in message
news:PFJPe.1266$kE2.586@newsfe3-gui.ntli.net...
> Hi,
> network but unfortunately it doesn't work at all when I try to access it
> over the internet - I get "Cannot find server" error page.
> the internal IP address of the server - I know this is working because I
> have accessed other services on that server externally. I have also
> purchased a domain name and have configured its A record to point to the
> server's external IP address. I have configured the host header name in
> IIS to the domain name.
> source as the internal LAN web server IP and the destination as "*".
> only have to open port 80 for IIS?
> TIA.
Reply to Anonymous
Archived from groups: comp.security.firewalls (More info?)
Sounds good.
Hm... did you think about the classical three zone concept? Perhaps, it
would be a good idea to have this web-server in a DMZ.
You only have to open port 80 usually - if you're not offering web on
another port. It's difficult to make a diagnosis from here, though.
Yours,
VB.
"Es kann nicht sein, dass die Frustrierten in Rom bestimmen, was in
deutschen Schlafzimmern passiert".
Harald Schmidt zum "Weltjugendtag"
Reply to Anonymous
- 0 +
source
Shoudnt that be the other way around? source as "*", destination as internal
LAN web server IP?
But also note the firewall might not see the destination as internal LAN web
server IP because of the NAT. Trying allowing port 80 traffic in to the
external IP from anywhere.
:: nick dell
:: programming & hosting
:: www.blnk.co.uk
> Hi,
network
the
> domain name.
source
only
> TIA.
Reply to user
There are 1106 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
