Tom's Hardware Forums » Graphic & Displays » Nvidia » Problem regarding Geforce4 TI 4800 SE VideoCard (128 mb ram)
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Problem regarding Geforce4 TI 4800 SE VideoCard (128 mb ram)
More Information
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Hello everybody!
I do not know if this is the right place to ask about this problem, but it
is a Nvidia graphic card, so I will take the chance. Excuse me if it is the
wrong place..
The problem is I own a Nvida Gforce 4 Ti 4800 SE graphic card with 128 mb of
ram. The Bios version is
4.28.20.21 and the drivers are version 6.14.10.5672, but the adapter driver
states driver version 5.6.7.2 (driver date 24.03.2004)
Now to the problem. Under the flip Desktop Settings/Advanced/GeForce4 Ti
4800 SE the Bustype is set to PCI. Before I uptated the driver it stated PCI
(AGP) in parentecis. The settings in Bios says that the main graphic slot is
AGP and with 128 mb of ram.
I also ran Sandra 2004 pro, and got the answer that it was problems
regarding my bustype of the graphic card! But I can assure you! It is AGP,
the card is fitted in an AGP slot and everything! I can also add that I
builded the computer myself. Can someone please help me? I am now in dire
need of full graphical burst rate on my graphic card, and I can't have my
computer believeing it is a "slow" PCI card!
Thanks in advance!
Niccolado
Related Pr oduct
More Information
"Nicolado" <nicolado@online.no> wrote in message
news:GuuMc.5120$Mq3.96259@news4.e.nsc.no...
> Hello everybody!
the
> wrong place..
of
driver
That's normal.
PCI
is
There could be a problem with the chipset ( or motherboard ) driver. Is it
up-to-date?
Does the entry under Display Adapters in Device Manager display the name of
the gfx card or just "VGA (generic)"?
Tony.
More Information
"The Black Wibble" <scanner@free.net.nz> wrote in message
news:9%AMc.160$zS6.30486@news02.tsnz.net...
>> Hello everybody!
>> it
> the
>> wrong place..
> of
> driver
> That's normal.
> PCI
> is
>> AGP,
> it
> up-to-date?
> of
> Tony.
Hi!
Under adapter it recognic ed the gfx card. it states type: Nvidia Geforce4
Ti 4800 SE
Adapter information
Chip Type: Geforce4 Ti 4800 SE
DAC Type: Integrated RAMDAC
memory Type: 128 MB
Adapter String: Geforce4 Ti 4800 SE
Bios Information: Version 4.28.20.21.00
Mother Board is: Elitegroup, Via Technologies, Model KT400-8235. It should
be up todate, because I bought
everything together. No new upgrades etc. Can not
remember tough if I set any jumpers
regarding PCI or AGP tough...Not sure.
Nic
More Information
"Nicolado" <car-nico@online.no> wrote in message
news:1wBMc.5182$Mq3.97050@news4.e.nsc.no...
> Hi!
> Ti 4800 SE
> Adapter information
> memory Type: 128 MB
not
> Nic
The motherboard is either an L7VTA (1.1), or an LVTA2 (2.0) because they
are the only two Elitegroup motherboards with the KT400/8235 chipset. See
here: http://tinyurl.com/64jsn. I can find only driver updates for the IDE,
LAN, Modem, and sound ( http://tinyurl.com/3kkmf ). All I can suggest is to
install DirectX 9.0b if you haven't already, and install the lastest nVidia
drivers which is rev 61.76, then see if that fixes things.
Tony.
More Information
Hi!
yes, I have the L7VTA version v1.1 you mentioned. I am still afraid for this
did not work out my problem. It is so frustrating. I checked
http://www.digit-life.com/articles [...] kt400.html
where I got it confirmed that there are no jumper setting for choosing AGP
or PCI. Only Bios setting. So. Why do I still have problems...?
news:XfDMc.184$zS6.33390@news02.tsnz.net...
>> Hi!
>> Geforce4
>> Ti 4800 SE
>> Adapter information
>> memory Type: 128 MB
>> should
> not
>> Nic
> IDE,
> to
> nVidia
> Tony.
More Information
news:TOQMc.5225$Mq3.97995@news4.e.nsc.no...
> Hi!
this
I don't know. You wrote that in Display Properties the Bus Type was PCI
(AGP) until the drivers were updated. I assume you've tried nVidia's most
recent drivers (ver 61.76) without any success. If games are running slower
and benchmark scores are down, then the only path to take is to revert to
the driver version which identified the Bus Type as PCI (AGP).
Tony.
More Information
news:4zYMc.304$zS6.51272@news02.tsnz.net...
>> Hi!
> this
>> AGP
> slower
> Tony.
Maybe, but the benchmarking program Sandra 2003, wich I used, still informed
me at that time I still used old drivers, that there where problems
regarding my gfx card. It recogniced my card as AGP slot not in use, or not
fully compatible... And, believe me. They are! Any good tips?
Nic
More Information
news:nD0Nc.5271$Mq3.98924@news4.e.nsc.no...
informed
not
> Nic
The L7VTA is a fairly common motherboard, yet after googling around the
internet I can't find other people with the same problem you're having. You
could try loading the BIOS defaults, then saving them. If that does not
help then think about backing up important data on to a CD or another medium
and do a clean reinstall of Windows. After reinstalling Windows make the
first thing you do is to install the chipset (or motherboard ) drivers, then
the video card drivers, then go to Display Properties to check the Bus Type.
If at this stage the bus type in Display Properties is ~still~ PCI, then I
suspect the PSU is not providing the graphics card with enough juice.
Tony.
More Information
Try these drivers: http://www.viaarena.com/?PageID=403
Tony.
More Information
Tony! You are a lifesaver!!
After I downloaded this patch and updated my system the status changed from
PCi to AGP 8X!!!!!
Now, I have not tested it yet with any games, but just that the system shows
AGP 8X means that
this patch work!!
Thank you! Thank you indeed!!
Nic!
news:QL3Nc.410$zS6.59456@news02.tsnz.net...
> Tony.
More Information
news:9o9Nc.5109$v04.75306@news2.e.nsc.no...
from
> PCi to AGP 8X!!!!!
shows
> AGP 8X means that
> this patch work!!
> Nic!
Woo hoo! I'm happy everything worked out. That was a tricky one.
Tony.
Add a reply
Google Ads
News
OCZ announces PC-4800 EL DDR Platinum Limited Edition
Published on March 02, 2005
OCZ announced a new high-performance DDR600 memory module. Read more
OCZ announces new DDR400/600 memory
Published on July 17, 2005
OCZ said it has added the PC-4800 Platinum Elite Edition (EE) to its memory lineup. Read more
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
AMD expands 65 nm Athlon 64 X2 roadmap
Published on September 27, 2006
AMD will expand the roadmap for its 65nm-made Athlon 64 X2 CPU portfolio (codenamed Brisbane), with the series lineup adjusted to feature processor clock speeds differentiated by 100 MHz, instead of the 200 MHz, according to motherboard makers. Read more
Latest Reviews & Articles
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
Stalker: Clear Sky - Is Your System Ready?
Published on September 30, 2008
Thinking about picking up the latest update to Stalker, but not sure if your graphics subsystem can handle it? Hang on as we take you through a performance tour and demonstrate how the game has been prettied up. Read more
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
