Archived from groups: comp.security.firewalls (More info?)
Yaff <novirus@junkaei.ca> wrote:
> It took me couple days to find out it was only a bad MTU setting.
I think, the setting was OK, but many DSL providers require a smaller
setting. You can find this in the documentation of the DSL provider
usually.
> Make sure you set the router/firewall MTU to its optimal value.
Optimal? You mean, small enough, because some providers have such
problems.
Yours,
VB.
"Es kann nicht sein, dass die Frustrierten in Rom bestimmen, was in
deutschen Schlafzimmern passiert".
Harald Schmidt zum "Weltjugendtag"
> problems.
Optimal means not too small and not too large. The default MTU at 1500 in
the Netgear was too large.
Optimal value in my case is 1456 according to the test describe in the link
above.
"Setting your computer's MTU value too low would make downloading less
efficient because a greater percentage of the packet is taken up by the
packet header which contains a variety of information about the packet,
source, and destination. However, setting the MTU too high can also decrease
efficiency. Other computers on the Internet might not be able to handle MTU
values of a certain size. If you set your computer's MTU value too high,
some computers along the delivery path would be required to break these
packets into smaller pieces before accepting them and passing them to the
next computer. This "Stop. Break. Go." processing of packets can
dramatically slow down data transfers."
> > problems.
I'd not call a compromize "optimal". But I don't want to nitpick ;-)
Yours,
VB.
