Geforce3 Ti200 monitor blinking!
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
I have been having a continuous problem with my monitor blinking (blank
screen) sporadically. This blinking happens anywhere from a few to 10
times a minute, but only when the computer is working. At idle this
blanking doesn't occur. This always happens during first boot, but if I
re-boot then the problem doesn't occur.
This happens under WinXP SP1,WinXP SP2 and Microsoft's and Nvidia's drivers.
Any Ideas what could be causing this problem?
Any information is greatly appreciated!
Nick
4 answers Last reply
More about geforce3 ti200 monitor blinking
  1. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    > drivers.
    > Nick
    How often do you degauss your monitor? It seems as though you might
    have a monitor without the option or it's getting old. Everytime you
    turn on your monitor or reboot, a good monitor should automatically
    degauss itself. Flickering and wavy lines are symptoms of a screen
    that's become over-magnitized.
  2. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    Which driver version are you using?
    DaveW
    "Nick" <nfunk@rtconline-SpamNot.com> wrote in message
    news:cg39oe113bi@enews2.newsguy.com...
    drivers.
    > Nick
  3. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    I had that problem on my old system and never fixed it.
    I just replaced my hard drive and the new drive is bad, the blinking
    problem has now started on this system. I'm hoping that when I replace the
    bad hard drive the problem will go away.
    Mac Cool
  4. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    The monitor is a 19" Samsung SyncMaster 955DF which is only about 1 year
    old that degauses each time it comes on. The Nvida driver is 5.2.1.6
    and the Geforce3 card has bios 5.2.1.6
    I had a previous Nvida driver not sure which version but it did the same
    sporadic blinking which can be cured with a second reboot. Afterwhich
    eveything is fine.
    > drivers.
    > Nick
Nvidia Monitors Graphics
