Tom's Hardware > Forum > Systems > Gateway2000 > wireless network problems
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
Old GW p2 233 (to cel 466) with a clean install of win98se fitted with
a Netgear wireless USB adapter (MA111). The host computer is wired to a
Comcast cable modem and I recently upgraded this OS from 98se to WinXP
home w/o problems. This is connected to a Netgear MA814 v2 router. The
GW will see the router signal, but not share the broadband connection.
It did work briefly before another reformat of the GW C: drive(though I
don't think it connected with the host comp off). I've mucked with the
setting to no avail. Dropped firewalls, etc. I posted this on a
wireless ng as well. Cheers
Sponsored Links
Do the channel and SSID used by the MA111 match those in use by the wifi router?
Does the router assign IP addresses as a DHCP server? Does the TCP/IP stack for
the MA111 expect to have an assigned IP address? When you run WINIPCFG, what
does it show for the MA111??? ... Ben Myers
Reply to Anonymous
Ben, I'll supply the beer if you come here and answer those
questions..or at least wait til I get home ....;-). So many
questions.....
Reply to Anonymous
Where is "here"? I can't get there from here... Ben
>questions.....
Reply to Anonymous
There are 580 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
