Tom's Hardware > Forum > Graphic & Displays > Nvidia > Another 6800 power supply related question.
Forum Graphic & Displays : Nvidia - Another 6800 power supply related question.
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
I see people talking about using a dedicated power supply dongle for their
6800 connection, but so far, I've yet to see official documentation from
manufacturers (like BFG) saying this. The official BFG documentation says
that for cards that use two power connectors (like the 6800 Ultra), you
cannot split a single power supply connection between the two connectors on
a card, but that you CAN share each of the two power supply cables used with
OTHER devices. Are people just misinterpreting this rule, or have some
people actually run into issues by not using a 100% dedicated dongle for
their 6800 power connections?
Thanks,
Larry
Sponsored Links
"Larry L." <larryalREMOVE2REPLY@socal.rr.com> wrote in message
news:G%DWc.11440$Bt5.10519@twister.socal.rr.com...
> on
> with
> Thanks,
> Larry
It probably depends on the number of other devices. Sharing with
more than one other device may cause problems. I have a BFG 6800 ultra OC
I had to configure my system so one power connector was only shared with one
other device and the other on its own.
Since then I've added a supply so the BFG is powered by its own supply.
Jim M
one other device
Reply to Anonymous
one
> Jim M
> one other device
I'm not sure I follow. Are you saying that you are running TWO power
supplies for one system?
You say you "had to" configure your system so the 6800 power connector
shared with only one device -- exactly what problems were you having such
that you found this necessary?
Thanks,
Larry
Reply to Anonymous
news:JGGWc.11444$Bt5.7103@twister.socal.rr.com...
> one
>> Jim M
>> one other device
> Thanks,
> Larry
Yes I'm running two supplies on one system.
At random times in windows my screen would
go blank and I would have to turn off my system
and restart it. After changing the power set up
I haven't had that problem.
Jim M
Reply to Anonymous
"JBM" <jmanning95@hotmail.com> wrote in message
news:SJmdna5hFdPyo7bcRVn-qw@comcast.com...
What wattage PSU is powering the 6800UOC?, interesting configuration. GPU
having it's own dedicated PSU.
Reply to Anonymous
This issue is way overblown. I've been tested my BFG6800u for weeks,
and it just doesn't matter how I split them off. I've used:
generic 300w
zalman 300w
tagan 480w
antec 430w
in all split-off/dongle configs, oced to 446/118 core/mem.
works fine .
Jeff B
Reply to Anonymous
"Richard Dower" <richarddower@hotmail.com> wrote in message
news:cgfp6e$eju$1@kermit.esat.net...
300 watts
Reply to Anonymous
http://www.xbitlabs.com/articles/v [...] power.html
http://takaman.jp/D/?english
Ed Light
Smiley :-/
MS Smiley :-\
Send spam to the FTC at
uce@ftc.gov
Thanks, robots.
Reply to Anonymous
"Ed Light" <nobody@nobody.there> wrote in message
news:bcPWc.102250$Lj.96604@fed1read03...
Excellent links.
Reply to Tim
There are 1268 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
