Tom's Hardware > Forum > Graphic & Displays > Nvidia > Inno3d Geforce FX5200 - Poor Display Quality
Forum Graphic & Displays : Nvidia - Inno3d Geforce FX5200 - Poor Display Quality
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
I have just purchased a nVidia Inno3d Geforce FX5200 graphics card for my
computer mainly for its dual monitor display capabilities and I am
disappointed with the screen display quality on my second monitor. I am
running XP sp2 using a flat panel monitor as the main display (which is
fine) and a 17" CRT and the second output. I have tried swapping the
monitors round then the 17" CRT is fine and the flat panel not. Any one any
ideas please
Thank You
Alec Green
Sponsored Links
Which ports do you use to connect the monitors? Dual VGA ( D-Sub ) or
Dual DVI or one of each? Which connector has a clean signal?
The GeForce FX cards are supposed to have a noisy DVI output according
to a post on this ng a few months back, which makes it really bad for
high resolutions like 1600x1200@60Hz.
> ideas please
> Thank You
> Alec Green
Reply to Anonymous
There are 1255 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
