Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
> Looking at 6800 card but what is a "hard disk drive power dongle". Is
> this just the normal HD plug ?
It's a 4-prong power supply plug. The 6800 cards require two power supply
connections, but Nvidia usually sends a splitter with these cards in order
to only require one connection from the power supply.
Only the 6800 Ultra requires two connections, the 6800 GT and standard 6800
have only one.
"Mr. Brian Allen" <blah@blah.com> wrote in message
news:10j3unf9dnfdn70@corp.supernews.com...
On Sun, 29 Aug 2004 09:19:17 -0700, "OldFartJAC"
>have only one.
So it's the normal plug? Why don't they say that ? I don't know anyone
that calls it a dongle.
Well, really 2, my understanding is that you should use two seperate
dongles, and use the splitters on each dongle or better yet on the other
dongles for your hard drives.
I just installed a 6800 Ultra and couldn't post until I used 2 seperate
dongles, one of them using a splitter conecting to a hard drive and the
other one is just for the GPU and nothing else attached.
It's a technical term.
NoRemorse
"Expect me when you see me."
"bp" <none@comcast.net> wrote in message
news864j0hkpgprqggu8gps60hcpepd7alk66@4ax.com...
6800
> >have only one.
supply
order
On Sun, 29 Aug 2004 18:03:20 GMT, "MJ" <mkjimenez@REMOVEpeoplepc.com>
>I guess it's whatever works with your PSU
The 6800 OC only needs one. I bought it today .
For anyone with a older CPU (not the latest and greatest) and as been
told that you won't see any benefit unless you upgrade your CPU I can
tell you they are wrong.
I had a asus A8N-e deluxe amd64 3000+ and a 9800pro
3dmarks gave that setup a 5882
Well that board blew up (long story) so I threw together a new PC with
an old asus a7s333 amd 2100+ xp and the 9800pro
3dmarks was 5280 I was surprised by the small difference
But I then put the 6800 oc in the 2100+ PC and 3dmarks score is 7892
So there is definitely a benefit.
I'll have to see how it runs when I get the 64bit system put back
together.
> together.
> Later
Keep in mind that 3dmark 2003 shows very little variance in scores
between different CPUs but the same graphics card.
Anyway, I would add you will still be able to run higher resolutions,
use higher quality options etc with the newer card. Sometimes, even
that's enough. Myself I'm using an AMD 2400+ with a GF4 Ti 4400, and
there are many games that are fill-rate limited on it, and would benefit
from a graphics card upgrade.
I guess that depends on what your talking about when you say "little
variance." I've seen people get about 1000-1500 points higher than me
with a much faster CPU. Although I'm already at 11538. That is
pretty close to 10-15%. Although a lot of it is in the first test
> pretty close to 10-15%. Although a lot of it is in the first test >
> Eric
There was a hardware site that did some tests just swapping out
different CPUs to see what the difference was, but I can't remember who
it was and my google searching isn't bringing it up... But anyway, the
results were that the CPU made negligible difference.
Maybe these people that are scoring better are overclocking, or using
different drivers?
If you want to test, try underclocking your CPU and see if it makes any
difference. I'd be interested in seeing if it does indeed make a difference.
> different drivers?
Here are the results with my 6800GT @ 400/1.1
P4 2.6C stock - 11512
AMD A64 3200+ Clawhammer overclocked 200Mhz - 12266
