G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Just bought a 6800 vanilla graphics card - ie the 128 MB version and I
am having a few probs. Doom 3 ran OK on low quality on my Geforce 5600
at 1280 x 1024 but with the 6800 it runs worse - well it runs OK but
seems to stop every now and again and kind of judder which renders it
unplayable. Never did it on the 5600. Also, the tinbury demo from the
nvidia site runs about 4 frames a second and the clear saiing and
mermaid - (nalu?) don't work at all - just a black screen with the
control menus at the top ????
Using a 350 Watt power supply, Athlon 2500 XP barton 333mhz - 512MB
ram, windows XP pro and SP 2 - freshly unstalled the other day and
nvidia drivers 61.77. Oh, and direct X 9c. Yup, not the latest system
I know but I suspect something somewhere is a bit iffy. From what I
have read on even the basic 6800 I should be able to run doome 3 on HQ
at 1280 x 1024 with no probs. (FSAA is off by the way)
ANy suggestions ? can;t believe the 6800 isn;t that much better than
the 5600 ? NOt after spending £170 on it anyway.
