Texas Instruments (TI) has unveiled several new battery management ICs, including its next-generation Impedance Track "gas gauge" chipset, to improve battery performance and protect multi-cell, lithium-based battery packs used in notebooks and other systems. Read more
On October 24, 2006, Fujitsu received a report from a customer in Japan that a Fujitsu notebook with a battery pack subject to a recent replacement program by Sony had an incident in which the battery pack overheated and sparked. After investigating the incident together with Sony, it has been concluded that the incident resulted from the Sony-made battery pack, and Fujitsu is now pursuing further detailed investigations. Read more
Despite that some industry players expect battery cell supply will reach an equilibrium in the fourth quarter, sources at Taiwan notebook battery module makers have noted that it is still too early to tell whether supply will be enough to feed demand. Read more
Canon issued a safety advisory today for its PowerShot A530 and A540 digicams. Read more
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. But at the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
While two other 500 GB mobile hard drives have been available for a while, WD is the first to release this capacity in a model using the standard 9.5 mm height with two platters. Read more
We recently built a $2,500 gaming system with three GTX 260 Core 216 graphics cards, noting that these were less expensive than two GTX 280s. In the performance-value game, is 3-way SLI in the cards? Read more
We’ve built, overclocked, and tested our $625, $1,250, and $2,500 performance machines. How will these three systems compare in overall performance and value? Read more
Tom's Hardware Forums »
PDA
PocketPC »
iPaq5555 GSM Slot under battery??? Possible to use as a ph..
| Bottom | |
| Author |
Thread : iPaq5555 GSM Slot under battery??? Possible to use as a ph..
PDA
PocketPC »
