Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
I have a Gateway VX900T CRT 18 inch viewable monitor. It's actually a
replacement monitor for one that was defective. Fortunately, we still had
our warranty thru Gateway and they sent us another VX900T. This happened 3
years ago, and I'm assuming the replacement monitor was new. But who knows?
Last night, while the monitor was running, it made a moderately loud
popping sound, the screen went black, then the picture came back. All this
happened in about 2 seconds. I turned off the system and unplugged the
monitor for about 20 minutes. Hasn't happened again. Any ideas what this
may signify? IIRC, this popping sound happened with our first Gateway
monitor, which was one of the reasons we took it in for maintenance.
It was a warning shot! The next one goes right in the back of the
monitor... 8-)
I'd start looking for a replacement soon.
"History Fan" <IreallyHATEspam@iREALLYhateSPAM.com> wrote in message
news:bEHWd.4384$N83.2124@fe37.usenetserver.com...
a
knows?
this
On Sun, 6 Mar 2005 13:05:53 -0500, "History Fan"
Wrong assumption when dealing with GW warranty replacements.
>Any ideas what this may signify?
Probably the same as a past known issue with their EV700s. The
flyback transformer's insulation breaks down and you get high voltage
jumps to ground which sound like a firecracker going off each time it
does it.
"Dogface" <DogFace@doghouse.com> wrote in message
news:rTIWd.302$rk1.251@fe03.lga...
> monitor... 8-)
A pity if true. This monitor has excellent picture quality.
However, it does take up a lot of space, weighs a ton, and I did have my eye
on those attractive looking LCD monitors at Circuit City recently.....
Back in the dim and distant past when I serviced TV's it was a common
occurrance to have periodic loud snapping noises emanate from the picture
tube. Caused by flakes of matter coming off the tube cathode and
incinerating (snap) when the high voltages arced across the resulting short
circuit. I never saw a tube fail even though the snapping occurred for
years. I wouldn't worry too much about it until you see a full failure then
just discard - new ones dont cost much more than repairs.
As far as the flyback transformer failing - they were always catastrophic
(ie. when they failed they were done).
Good luck
news:1_JWd.4399$N83.2487@fe37.usenetserver.com...
>> monitor... 8-)
> eye on those attractive looking LCD monitors at Circuit City recently.....
Succumb to the temptation! I did (Samsung). You won't regret it. Except
buy it from www.neweg.com and you'll get it for a good price. Stop using
your monitor to heat your house and get a lot of space back for the rest of
your junk.
> > monitor... 8-)
eye
I have the same monitor, have had it for 6 years, a couple years ago the
same thing happened to me, I also thought my monitor was starting to fail
but have never heard a pop since and has been working great.
Don
> 3 years ago, and I'm assuming the replacement monitor was new. But who
> knows?
> this happened in about 2 seconds. I turned off the system and unplugged
> the monitor for about 20 minutes. Hasn't happened again. Any ideas what
> this may signify? IIRC, this popping sound happened with our first
> Gateway monitor, which was one of the reasons we took it in for
> maintenance.
