Yes No
Ads
Tom's Hardware > Forum > Networking > Firewalls > Wallwatcher problem
Wallwatcher problem
Forum Networking : Firewalls Wallwatcher problem
Archived from groups: comp.security.firewalls (More info?)
To learn more about what is blocked by my Linksys router and my
Sygate Firewall, I installed WallWatcher and chose the Linksys BEF
series as my router (BEFSR41).
After running it for 24 hours, and deliberately creating incoming
stuff via music streams and other routes, WallWatcher continued to
show nothing in the logs.
I went to Bandwidth and tried "test snmp". This resulted in Sygate
blocking the test and blocking all traffic from my standard router
IP address for 10 minutes.
Do I leave this "allowed" in Sygate? And if so, is it worth it or
am I creating a risk I didn't have before?
I don't fully understand what's happening.
TIA
Louise
Reply to louise
louise <nospam@nospam.com> wrote in news:MPG.1d935c1c422f12549896f6@news-
server.nyc.rr.com:
> TIA
> Louise
The personal FW must allow incoming traffic on UDP 514 from the Linksys
router's device IP of 192.168.1.1.
Duane :)
Reply to Anonymous
"louise" <nospam@nospam.com> wrote in message
news:MPG.1d935c1c422f12549896f6@news-server.nyc.rr.com...
One other thing, the router must be set enabled to broadcast the logs to all
machines on the LAN and that IP will be 192.168.1.255 -- broadcast to all
machine on the LAN. Or you can set it to 192.168.1.100 if one of your
machines on the LAN has that IP and the log data will only be sent to that
IP/machine where WW is installed. You should read the router's user manual
as there is Admin screen to enable the broadcasting of the router's syslog
data or get on the phone with Linksys Tech Support.
You don't have things configured right it seems.
You have to tell Sygate to accept traffic on UDP Port 514 is where the
syslog data traffic from the router is being sent. The IP you would trust is
192.168.1.1 the device IP of the router. You can do it for the 514 UDP port
only or you trust the device IP on ALL Ports, which you should do and is a
better solution, if you cannot do it for solely UDP port 514.
Better yet for the time being, disable Sygate on the machine and watch
Wallwatcher work, after all the machine is setting behind the protection of
a NAT router. You can enable Sygate and figure out how to make rules with
Sygate to open/unblock the UDP 514 port.
How can there be a risk? The machine is setting behind the router and it is
protecting the machine from the Internet and Sygate is just a bonus. And for
now Sygate is in the way.
There is nothing to understand and it's basic.
1) Make sure the router is broadcasting the syslog data.
2) Configure the PFW solution to accept traffic from the router's device IP.
3) That's it. At this tine WW is not getting any inbound traffic on UDP port
514 to show any data.
Duane :)
Reply to Anonymous
I think you need to activate logging in your router settings (
administration page : log = yes ).
The default is off.
Reply to Anonymous
testing snmp ( do the test 2 * ) could force a warm router reboot.
BEFSR41 hates this snmp testing!
It must have something to do how WallWatcher does the test.
In my case I'm only 30 seconds "off line".
I also had already two times a spontaneous?? router reset to the router
defaults.
If the WW logs show nothing I know I had router problems again and have to
set all my router settings again.
Reply to Anonymous
"joly joker" <me@privacy.net> had to wrote :
> WallWatcher doesn't do lookups on the internet. It only looks in your
> router.
sorry, I was wrong. You could have WW logging options set;
like convert IP addresses to URL's.
Reply to Anonymous
> Could you tell me exactly how you configured Sygate since we are
> using the same combination of hardware and software.
first off all could you tell us some off your router settings for this
problem ( only if you still have this problem)?
Are you using BEFSR41 v1, v2 or v3 and which WIN98, XP or other OS you are
using?
In v3 there is an Administration page where you have to set ( and save )
Log --> must be yes.
Logviewer IP address --> must be(?) 192.168.1.255 ( most easy, every PC in
your LAN could get the router info).
In WW you have a logging, a display and a router page which could give you
trouble.
What could be wrong? Wrong router selected on the router page? Nothing to
log? Everything cleared on the display page?
I don't think this is your problem, but WW is a part in this not functional
process.
You could start with Sygate allowing WallWatcher full access and if it's
working you can finetune the WW settings in Sygate to only use the ports
neccessary. If WW is already in the list of the allowed programs in Sygate,
remove it and let Sygate allow WW again without limitations.
Reply to Anonymous
- 0 +
In article <dgh9rq$ndb$1@news5.zwoll1.ov.home.nl>, me@privacy.net
says...
> using?
> trouble.
> process.
Router is: Linksys BEFSR41 - version 2
OS is Win XP Pro
I enabled logging on the router.
WW provides a "BEF series" option for choosing your router and
that's what I chose
Router IP address is correct
As you suggested, I removed WW from Sygate Applications. I also
uninstalled and reinstalled WW just in case something had gone
wrong with the installation.
In WW, there is an option to ping your router (on the special tab).
I tried pinging my router and Sygate came up asking whether I
wanted to allow WW, etc. I checked the always box and said yes.
Nevertheless, when I then tried to ping my router from WW, Sygate
came up and blocked it.
Now - if I go into the advanced settings for the WW application in
Sygate, there are many options and I've no idea what to choose for
any of them:
Application Restrictions (trusted IPs) - it is now blank
Remote Server Ports TCP and UDP - they are now blank
Local Ports TCP and UCP - they are now blank
NOTE - there are long drop-down menus for the Remote server ports
and the local ports and I do not understand them.
Allow ICMP traffic is checked
Act and Client and Act as Server are both checked
NOW - I turned off Sygate and pinged my router from WW
successfully. However, for me, this is not a long term solution
and I would like to be able to configure Sygate to allow it.
BTW, the port is 162 for one router (that's all I have). There is
an unchecked checkbox for "multiple routers), which is for ports
162 and 514.
Now - what to do?
TIA
Louise
Reply to louise
There are 1790 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
My desktops internet. HELP
By Realbeast, 15 hours ago:
Sure could be a virus or malware, you should use a good free antivirus and...
Best offers
Top experts
