Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
I've had a GeForce4 Ti 4600 (ASUS V8460) for a while, never had any problems.
Now there are some minor glitches on the first boot up screen with the memory
check, then again on Windows XP load screen. When Windows boots up, there
are many visible dots, in about 6 vertical lines across the screen. Dragging a
Window across the screen makes the dots draw on it, like etch-a-sketch, as
seen in this pic:
http://www.k-j.pwp.blueyonder.co.uk/glitch.jpg
And when scrolling up or down web pages, the lines of dots join up into straight
lines. Refreshing or reopening the window gets rid of the pattern, but the dots
are still there and it happens again.
No idea what's wrong, but seen as how I'm not just seeing a change in Windows
(because of the booting up minor little line glitches), I'm guessing it's some sort of
hardware trouble? Can anyone tell me what the problem is?
TIA
--------------= Posted using GrabIt =----------------
------= Binary Usenet downloading made easy =---------
-= Get GrabIt for free from http://www.shemes.com/ =-
seen in this pic:
TIA
