Archived from groups: alt.comp.periphs.videocards.nvidia (
More info?)
"dvus" <dven1invalid@adelphia.net> wrote in message
news:310kanF354e6gU1@uni-berlin.de...
> Nerdillius Maximus wrote:
> > "RonK" <I'mnuts@home.com> wrote in message
> > news:OJxqd.7604$Ad3.408875@news20.bellglobal.com...
> >> If you are running XP then you need more memory. XP uses a lot of
> >> the memory and Doom 3 needs a lot as well. You should go up to 1 gig
> >> of memory.
> > Yep. Doom 3 works best with a gig or more even under W2k, and it's
> > choppy and uglier under 98SE no matter how ya slice it...
> > XP can be put on a serious Slim-Fast diet and it'll help a little. If
> > you have as few services running in the background as possible, and
> > no mile-wide taskbar with RealAnything, IM gar-bagio, or Weatherbug
> > or other spyware, file-sharing, folding clients, Windows Messenger
> > that deserves a quick death, or Automatic Update service poo running,
> > it gets better...
> XP seems to indicate that M$ OE needs Windows Messenger running to work
> properly. Many times I've closed IM only to have it re-load when I open
OE,
> and I have unticked the "Automatically Load Windows Messenger" box in the
> options menu. IM seems to be one of those things that won't go away.
Nope. Ya just gotta shoot it, is all ;-) Try www.grc.com, get the utility
"Shoot the Messenger". This is assuming you're referring to Windoze
Messaging (Spam) Service, not MSN Messenger with the little taskbar icon
that looks suspiciously like a chess pawn (oh, the arrogance!), which is
also somewhat pervasive but easy to get rid of. I don't use IM apps at all,
so it never gets installed in the first place. And you can stop its stub
from loading by looking under the "run" keys in the registry (right next to
RunOnce which is quicker to find, because there are a million instances of
"run" in the registry) and deleting that what you don't want to have running
on startup.
> dvus
