Archived from groups: alt.comp.periphs.videocards.nvidia (
More info?)
homer wrote:
> "CapFusion" <CapFusion.Yo.@hotmail.Hehe@CrazyJunk.Com> wrote in
> message news:ibOdnY0G7o14eyncRVn-pA@megapath.net...
>> "homer" <homer25_2000@yahoo.com> wrote in message
>> news:41b4e487$0$50912$ed2619ec@ptn-nntp-reader01.plus.net...
>>> message news:vNSdnXvARfJMJincRVn-sg@megapath.net...
>>>> news:41b1a976$0$53001$ed2619ec@ptn-nntp-reader03.plus.net...
>>>>> message news:2N2dnWMYrtf8fS3cRVn-iA@megapath.net...
>>>>>> news:41b0cbc7$0$50867$ed2619ec@ptn-nntp-reader01.plus.net...
>>>>>>> I can't access the Nview display mode to get the pc to send a
>>>>>>> TV out signal via the composite video cable.
>>>>>>> According to the manual there should be a Nview Display Mode
>>>>>>> option which should allow me to select output devices.
>>>>>>> The drivers are version 6.14.10.5664
>>>>>>> Thanks for your time
>>>>>> Can you clarify -
>>>>>> Can not access nView Display mode as grayout or is not available?
>>>>>> CapFusion,...
>>>>> sorry CapFusion I should have been clearer..
>>>>> nView display mode is not available. I didn't know it existed
>>>>> until I saw
>>>>> it
>>>>> on the user manual, which uses my graphics card as an example.
>>>>> at the back of the pc i have svideo out, composite video out,
>>>>> vivo,dvi, sockets.
>>>>> thanks
>>>>> homer
>>>> That is alot better.
>>>> From this last reply, this implied that your card is detecting the
>>>> S-Vide /
>>>> Composite [RCA] etc and therefore do not have nView Display Mode
>>>> option in
>>>> your GeForce Menu.
>>>> Possible problem:
>>>> Cable maybe too long or not in good condition.
>>>> Both end of the cable may not be firmly attach.
>>>> I assume you using a dongle cable, if so, check if firmly connect /
>>>> attach.
>>>> Or the port maybe the issue.
>>>> Try update your driver to see if it will make any differences.
>>>> Can you try download the latest driver from nVidia -
http://www.nvidia.com/content/drivers/drivers.asp
>>>> Graphics Driver > GeForce and TnT2 > [your Operating System] >
>>>> Click on any link site.
>>>> Save to your local folder. Find folder and execute the download /
>>>> saved file. Follow those steps.
>>>> If your card still do not see nVidia Display, check the following -
>>>> Troubleshooting [Menu]
>>>> My connected TV is not being detected.
>>>> Detect display [botten]
>>>> In normal working card, you do not need to force detection of a
>>>> connection like a TV.
>>>> Try using another good S-Video or RCA cable.
>>>> CapFusion,...
>>> downloaded the latest drivers and nView display is now available!
>>> thanks BUT
>>> I still get no picture on my TV. I am using a RCA cable (my tv does
>>> not have s video)
>>> it looks like my card does not detect th TV
>>> I have tried
>>> Detect display
>>> still no luck....
>>> any ideas?
>> In nVidia Display Mode, what mode does it have listing?
>> Does it have Clone / DualView etc except Standard? If those listing
>> available, can you try them? Do you have the cable still attach from
>> your TV and your card?
>> CapFusion,...
> in nVidia Display Mode I have the following options...
> single display
> clone
> horizontal span
> vertical span
> dual view
> I have tried all the settings and get no picture on the tv
> it also has a detect displays tab
> which always only detects the monitor not the tv
> any ideas?
From you are describing, sound like your cable is not at par / condition OR
your card where the S-Video / RCA maybe defect.
The - detect displays tab - is meant to force or try to detect if TV is
attach.
BTW -
When you booting up your PC and while your TV is attach [assuming], do you
see display on your TV while during booting process?
If you do not see any display, I would and assume your TVout on the card or
the cable maybe the issue.
Enable TV out -
http://nvidia.custhelp.com/cgi-bin/nvidia.cfg/php/enduser/popup_adp.php?p_sid=GXDI2psh&p_lva=42&p_li=&p_faqid=32&p_created=1096498785
CapFusion,...
