Hello,
I trying to use windows 7's disk management tool to create a new partition, however it doesnt seem to be working.
I select my appropriate disk and select "shrink volume" but then it shows me that i have 0MB available to partition. This is strange because i have a 650GB HDD with almost 260GB free.
I tried using command prompt do partition, but it said the same thing; "0MB of reclaimable bytes" or something like that. I used disk clean up, i defragged, and i searched online; nothing helped.
Any help?
I'm trying to dual boot XP, and i really dont want to reformat windows 7 just to be able to install XP.
thanks in advance
Any help?
thanks in advance
