GeForce 6800 Ultra Problems
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
I recently put together a new computer. Its an Intel P4 3.0 GHz chip
on a P4C800E - Deluxe motherboard. I've got 1 GB of DDR RAM, SB Audigy
2 ZS Gamer, and, of course, the NVIDIA GeForce 6800 Ultra. I'm having
problems with some games, mostly 1st person shooters (Doom 3, Half-Life
2, Star Wars Battlefront, etc.). The game will run great for a while,
then everything freezes. Sometimes, it will restart automatically, but
most of the time, I just have to reset. I have updated the NVIDIA
driver, the Audigy driver, and drivers for the Intel chipset. I have
the most up to date BIOS. I just want to know what might be the
problem and what, if anything, I can do to fix it. Thanks in advance
for any help.
Todd
13 answers Last reply
More about geforce 6800 ultra problems
  1. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    Sounds like it could be heat or power related.
    Check the cooling on the card. Try running a fan on the card with your case
    open. Then test it out. If the problems go away then then overheating is most
    likely causing the problems.
    If it does not do anything then it could be your power supply does not have
    enough or barely enough wattage for your computer.
    You might also want to try using molex power connectors that are separate from
    everything else in your system.
  2. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    You don't say what size PS you're using, but I'd be willing to bet that's
    the culprit, especially with that power hungry 6800 card. Anything less than
    420-480 watts would be questionable in that setup.
    HTH
    "T-Bone" <toddbarlow@hotmail.com> wrote in message
    news:1102387589.154242.8680@c13g2000cwb.googlegroups.com...
    > for any help.
    > Todd
  3. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    > for any help.
    I had excatly the same issue with my Asus V 9999Ultra Deluxe, this was
    not a heating prolem nor was it power supply issue. I use a North Q 500w
    power supply and have a cool kabinet (thermaltake with 2front fans and 2
    backfans). The problem was corrected by turning engine clock from 425mhz
    to 400mhz. Try this first as this is easyly done, if it helps problem can be
    inveastigated
    form there, in my case i would say that the the gpu simply was not up to the
    task of 425mhz.
    Dorph
  4. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    I've had similar problems with my Evga. How do you turn the clock speed
    down? Is it in the Nvidia software or bios? See my post "6800 Ultra Power
    Issue" (I've tried it all!)
    Thanks for the info...
    "Dorph" <b_xxxxxx@xxx.dk> wrote in message
    news:cp4a70$sbv$1@news.cybercity.dk...
    >> for any help.
    > be inveastigated
    > the
    > task of 425mhz.
    > Dorph
  5. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    If the problem does not end up being power supply or clock speed, it could
    be RAM.
    I'm thinking at first the game is using only some of the RAM but after some
    period of time it finally starts to use the part that is damaged and then
    lockup occurs. But I'm hoping your problem is merely a clock speed issue.
    > for any help.
    > Todd
  6. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    The Asus V 9999Ultra have its own Asus drivers and it can be done
    from the drivers.For others than Asus it can be done by other
    programs, i dont use the Asus driver anymore and do it by using
    "powerStrip" a handy little program for all sorts of tweaks.
    If you try to download "PowerStrip" you will find adjustment-
    sliders for both engineclock and memoryclock under performance-
    profiles.
    D
    "Dave C." <dcc@geosurv.com> wrote in message
    news:vzitd.4067$yr1.678@newsread3.news.pas.earthlink.net...
    > Power Issue" (I've tried it all!)
    >>> for any help.
    >> be inveastigated
    >> the
    >> task of 425mhz.
    >> Dorph
  7. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    Ohh and forgot an even easyer method - download the coolbits reg.
    This little reg will open the hidden opotunity already build
    into the drivers.
    http://www.overclockers.com.au/techstuff/a_coolbits/
    Dorph
    news:cp4i55$17pg$1@news.cybercity.dk...
    > profiles.
    > D
    >>>> for any help.
    >>> can be inveastigated
    >>> the
    >>> task of 425mhz.
    >>> Dorph
  8. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    "Dave C." <dcc@geosurv.com> je napisao u poruci interesnoj grupi:
    >> be inveastigated
    >> the
    >> task of 425mhz.
    Then what's the point of Ultra card when you must lower gpu frekvencies?Then
    GT is the way to go.
  9. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    "Romano Cule" <alibaba@vip.hr> wrote in message
    news:cp96af$5ob$1@ls219.htnet.hr...
    >>> the
    >>> task of 425mhz.
    > frekvencies?Then GT is the way to go.
    Some how mine was set to 425mhz from the start - but i believe that standard
    on a
    6800u are 400mhz wich it will run fine.
    6800ultra 400mhz core and 1100mhz memory 16x1 pipelines
    6800gt 350mhz core and 1000mhz memory 16x1pipelines
    6800 325mhz core and 700mhz memory 12x1pipelines
  10. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    Some companies overclocked their cards to 425 MHz in the bios in order
    to try and differentiate from the competition. Thing is, just about
    every company decided to oc the cards since they were able to get them
    to run stably enough.
    I had tons of issues with rebooting, BSODs, games crashing, freezing,
    etc. Barring any issues with regards to the Ultra getting enough
    power, etc, a common fix I saw was to disable fast writes. That only
    helped partially. I came across a suggestion on Anandtech's forums to
    not downgrade the 3D clockspeed but rather overclock the 2D speed. I.e
    if your card is currently running at 425 for its 3D, overclock the 2D
    to the same amount. If you wish to overclock your 3D clockspeed
    further, make sure to do the same for the 2D clockspeed.
    I found that the best way to do this is to use nvflash, download a copy
    of your video card's bios, and use a program to edit it. Set the 2D
    clockspeed to the same speed as your 3D clockspeed. Save it and flash
    the updated bios to your video card.
    This fix cured all my stability issues, Whereas before I'd be lucky if
    I could finish a gaming session without freezing, I regularly have the
    computer running for 4-5 days without any issues (I manually reboot
    because of installing some update or some such activity but not due to
    lockups).
  11. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    > order to try and differentiate from the competition. Thing is, just
    > about every company decided to oc the cards since they were able to
    > get them to run stably enough.
    > I.e if your card is currently running at 425 for its 3D, overclock
    > the 2D to the same amount. If you wish to overclock your 3D
    > clockspeed further, make sure to do the same for the 2D clockspeed.
    > copy of your video card's bios, and use a program to edit it. Set
    > the 2D clockspeed to the same speed as your 3D clockspeed. Save it
    > and flash the updated bios to your video card.
    > if I could finish a gaming session without freezing, I regularly have
    > the computer running for 4-5 days without any issues (I manually
    > reboot because of installing some update or some such activity but
    > not due to lockups).
    Does a video card switch between modes during a game? Mine (Asus V9999)
    seems to have three modes, 2d, 3d and 3d gaming (or something like that).
    What determines the switch between modes, and does it happen often during a
    particular use?
    dvus
  12. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    Yes I believe it does but that's dependent on the game. Think about it
    this way. During loading, games usually have some screen with art or
    tips, etc about the area you're entering. The card would be in 2D
    mode. When the game loads up, you're switching to 3D rendering. I
    believe this switch, which also causes the clockspeed to change due to
    the different settings, is the culprit to the card hanging.
    I'd highly recommond you using nvflash, download a copy of your video
    card's bios onto your HD, and edit the clockspeeds in their. First try
    setting both 2D and 3D clockspeed to 400 MHz. Leave the memory speed.
    Reflash the bios to your video card and try playing. If there are no
    issues after this and you really want a few extra frames, go back and
    edit your video card's bios. Set them both to 425 MHz and reflash.
    A side note: I was unable to get this working successfuly when I used
    Coolbits or Rivatuner to set the 2D/3D clockspeed to the same setting.
    My computer would still crash and hang. Only by flashing the BIOS with
    the speeds corrected my issues. You could try using these utilities
    first and see if that helps.
  13. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    [re: 2D & 3D mode switching]
    > it this way. During loading, games usually have some screen with art
    > or tips, etc about the area you're entering. The card would be in 2D
    > try setting both 2D and 3D clockspeed to 400 MHz. Leave the memory
    > speed. Reflash the bios to your video card and try playing. If there
    > are no issues after this and you really want a few extra frames, go
    > back and edit your video card's bios. Set them both to 425 MHz and
    > reflash.
    > with the speeds corrected my issues. You could try using these
    > utilities first and see if that helps.
    I'll check this out, thanks.
    dvus
Nvidia Geforce Graphics
