Still no gameplay. Could this be the problem?
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
I recently purchased a new GeForce FX5200 in hopes of getting a game
to run. No luck. I meet the minimum requirements for the game (I have
a Pentium II, 400, 384 megs ram, small 6 gig HD) , so at the very
least the game should run, even though it may be slow. I make sure the
have the latest drivers for the card, and yet no game. When I click on
the icon, the screen goes white (sometimes)then black for 30 seconds
and then back at the desktop. What's up?
While exploring, I found under computer management, in a subdir called
conflicts/sharing that it listed two items on the same IRQ channel.
Could that be the problem? Here is what I saw:
System Information report written at: 12/13/2004 07:57:06 PM
[IRQs]
IRQ Number Device
11 NVIDIA GeForce FX 5200
11 Creative AudioPCI (ES1371,ES1373) (WDM)
3 3Com Windows Modem ISA ADI
14 Primary IDE Channel
15 Secondary IDE Channel
9 Intel 82371AB/EB PCI to USB Universal Host Controller
10 CNet PRO200WL PCI Fast Ethernet Adapter
1 PC/AT Enhanced PS/2 Keyboard (101/102-Key)
4 Communications Port (COM1)
6 Standard floppy disk controller
8 System CMOS/real time clock
13 Numeric data processor
12 Microsoft PS/2 Mouse
Lastly, I called the place I bought the FX 5200 and talked to the tech
for a while. he said that since I am getting the following message
(The WDM Video Audio Crossbar (ATIXBar) service failed to start due to
the following error:
The service cannot be started, either because it is disabled or
because it has no enabled devices associated with it.), the computer
is still trying to load the ATI drivers, yet there is no ATI card on
here. He said that that command should be deleted from the registry.
Ok. I've used several registry cleaning programs to scan the system
and while it found many erros, so say, not one listed ATI anywhere.
Anu suggestions?
Mark Ferrante
G
Guest
Guest
Ferrante:
> [IRQs]
> IRQ Number Device
It's been years since I dealt with IRQ issues but yeah having the sound
card and video card on the same IRQ could cause problems. If you have the
sound card next to the video card, move it; if possible, leave the slot
next to the AGP open. Either way, force one to use a different IRQ.
Mac Cool
G
Guest
Guest
"Mac Cool" <Mac@2cool.com> wrote in message
news:Xns95BEE331F5460MacCool@24.25.9.41...
> Ferrante:
>> [IRQs]
>> IRQ Number Device
> Mac Cool
Rubbish, it just doesn't matter, well as long as you are using Win2k or
WinXP you could have 4 on the same IRQ.
G
Guest
Guest
"Pete D" <no@email.com> wrote in message
news:xDvvd.72141$K7.27557@news-server.bigpond.net.au...
snip
Seven, actually, on some non-APIC-able mobos...
http://support.microsoft.com/default.aspx?scid=kb;en-us;314068
Read, please...
But I really don't think someone would want to run XP on a Pentium
II...that's almost like running Win95 on a 386 (been there, done that...) I
highly doubt he's that much of a masochist...
And as for the original poster: Do you have at least Win98SE (preferably) or
ME? Do you have DirectX 9.0 c installed? Does the card make it thru DXDiag
ok?
Did you completely uninstall ATI's drivers using their uninstall utility
before removing the card and plopping in that Nvidia card? If not, you
either get to become very familiar with the registry and manually editing
it, or become very familiar with reinstalling the ATI card and uninstalling
it properly, or become very familiar with your product key when you wipe it
all clean with that miraculous system restore tool called FDISK, and
reinstall everything from scratch...
Oh, and Creative cards, even the Ensoniq ones, aren't known for always
happily sharing interrupts...might want to try moving it into a different
PCI slot...
G
Guest
Guest
I am running Windows 200 pro. I ran dxdiag and got the following
information, which includes one error which can been seen in DxDian
notes:
System Information
Time of this report: 12/9/2004, 22:48:04
Machine name: FERRANTE
Operating System: Windows 2000 Professional (5.0, Build 2195)
Service Pack 4
Language: English (Regional Setting: English)
System Manufacturer: Gateway
System Model: G6-400
BIOS: Default System BIOS
Processor: Intel Pentium II processor, ~400MHz
Memory: 384MB RAM
Page File: 216MB used, 704MB available
Windows Dir: C:\WINNT
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0904 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. DirectDraw test results: All
tests were successful. Direct3D 7 test results: Failure at step 32
(User verification of Direct3D rendering): HRESULT = 0x00000000 (error
code) Direct3D 8 test results: All tests were successful. Direct3D 9
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce FX 5200
Manufacturer: NVIDIA
Chip type: GeForce FX 5200
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0322&SUBSYS_93091462&REV_A1
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (16 bit) (60Hz)
Monitor: SONY CPD-200ES
Monitor Max Res: 1280,1024
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.6693 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/29/2004 16:50:00, 3736704 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 10/29/2004 16:50:00, 2826944 bytes
Device Identifier: {D7B71E3E-4062-11CF-F76D-03B300C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0322
SubSys ID: 0x93091462
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}:
Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2)
Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}:
Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1)
DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}:
Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0)
DeinterlaceTech_BOBVerticalStretch
Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,2)
Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1)
Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0)
Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,2)
Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1)
Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0)
Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2)
Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1)
Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0)
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: Failure at step 32 (User verification of Direct3D
rendering): HRESULT = 0x00000000 (error code)
D3D8 Test Result: All tests were successful.
D3D9 Test Result: All tests were successful.
Sound Devices
Description: Creative Sound Blaster PCI
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1274&DEV_1371&SUBSYS_57538086&REV_04
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: es1371mp.sys
Driver Version: 5.00.2174.0001 (English)
WHQL Logo'd: Yes
Date and Size: 11/6/1999 05:11:56, 44528 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Standard
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 48000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x40
Format Flags: 0xCCC
DirectMusic
DLS Path: C:\WINNT\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode),
Output, DLS, Internal, Default Port
Creative Sound Blaster PCI, Software (Kernel Mode),
Microsoft MIDI Mapper [Emulated], Hardware (Not
Kernel Mode), Output, No DLS, Internal
Creative Sound Blaster PCI [Emulated], Hardware (Not
Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware
(Not Kernel Mode), Output, No DLS, Internal
Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 6/19/2003 14:05:04, 40176 bytes
Gameport Devices
+ Creative AudioPCI (ES1371,ES1373) (WDM)
| Matching Device ID: pci\ven_1274&dev_1371&subsys_57538086
| Service: es1371
| Driver: portcls.sys, 6/19/2003 14:05:04, 148208 bytes
| Driver: stream.sys, 7/9/2004 04:27:28, 48512 bytes
| Driver: wdmaud.drv, 6/19/2003 14:05:04, 21264 bytes
| Driver: es1371mp.sys, 11/6/1999 05:11:56, 44528 bytes
| Driver: ksuser.dll, 12/12/2002 00:14:32, 4096 bytes
+-+ Game Port for Creative
| | Matching Device ID: *ctl7001
| | Service: gameenum
| | Driver: gameenum.sys, 6/19/2003 14:05:04, 9808 bytes
PS/2 Devices
+ PC/AT Enhanced PS/2 Keyboard (101/102-Key)
| Matching Device ID: *pnp030b
| Service: i8042prt
| Driver: i8042prt.sys, 6/19/2003 14:05:04, 46992 bytes
| Driver: kbdclass.sys, 6/19/2003 14:05:04, 24528 bytes
+ Microsoft PS/2 Mouse
| Matching Device ID: *pnp0f03
| Service: i8042prt
| Driver: mouclass.sys, 6/19/2003 14:05:04, 21776 bytes
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll
(5.03.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll
(5.03.0000.0900)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll
(5.03.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll
(5.03.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File:
dpwsockx.dll (5.03.0001.0904)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll
(5.03.0001.0904)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll
(5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll
(5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not
run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: 3Com Windows Modem ISA ADI
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 TCP/IP Service Provider: CNet PRO200WL PCI Fast Ethernet
Adapter -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Age of Empires Expansion (DX7) - Registry: OK, ExeFile: EmpiresX.Exe
(<File Missing>)
World Championship Snooker (DX7) - Registry: OK, ExeFile: wcs.exe
(<File Missing>)
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 0.1 GB
Total Space: 6.2 GB
File System: NTFS
Model: WDC AC26400R
Drive: D:
Model: TOSHIBA DVD-ROM SD-M1202
Driver: c:\winnt\system32\drivers\cdrom.sys, 5.00.2195.6655
(English), 6/19/2003 14:05:04, 27984 bytes
Drive: E:
Model: Memorex 52MAXX 2452AJ
System Devices
Device ID: PCI_HAL\PNP0A03\0
Driver: C:\WINNT\system32\DRIVERS\pci.sys, 5.00.2195.6655
(English), 6/19/2003 14:05:04, 59312 bytes
Name: Intel 82443BX Pentium(r) II Processor to AGP Controller
Device ID: PCI\VEN_8086&DEV_7191&SUBSYS_00000000&REV_03\2&EBB567F&0&08
Driver: C:\WINNT\system32\DRIVERS\AGP440.SYS, 5.00.2195.6655
(English), 6/19/2003 14:05:04, 21008 bytes
Name: Intel 82443BX Pentium(r) II Processor to PCI Bridge
Device ID: PCI\VEN_8086&DEV_7190&SUBSYS_00000000&REV_03\2&EBB567F&0&00
Driver: n/a
Name: Intel 82371AB/EB PCI to USB Universal Host Controller
Device ID: PCI\VEN_8086&DEV_7112&SUBSYS_00000000&REV_01\2&EBB567F&0&3A
Driver: C:\WINNT\system32\drivers\uhcd.sys, 5.00.2195.6655
(English), 6/19/2003 14:05:04, 32848 bytes
Driver: C:\WINNT\system32\drivers\usbd.sys, 5.00.2195.6658
(English), 6/19/2003 14:05:04, 20688 bytes
Driver: C:\WINNT\system32\drivers\usbhub.sys, 5.00.2195.6689
(English), 6/19/2003 14:05:04, 40176 bytes
Driver: C:\WINNT\system32\usbui.dll, 5.00.2134.0001 (English),
11/30/1999 18:39:50, 59664 bytes
Name: Intel(r) 82371AB/EB PCI Bus Master IDE Controller
Device ID: PCI\VEN_8086&DEV_7111&SUBSYS_00000000&REV_01\2&EBB567F&0&39
Driver: C:\WINNT\system32\DRIVERS\intelide.sys, 5.00.2195.6666
(English), 6/19/2003 14:05:04, 4624 bytes
Driver: C:\WINNT\system32\DRIVERS\pciidex.sys, 5.00.2195.6672
(English), 6/19/2003 14:05:04, 22064 bytes
Driver: C:\WINNT\system32\DRIVERS\atapi.sys, 5.00.2195.6699
(English), 6/19/2003 14:05:04, 86672 bytes
Name: Intel 82371AB/EB PCI to ISA bridge (ISA mode)
Device ID: PCI\VEN_8086&DEV_7110&SUBSYS_00000000&REV_02\2&EBB567F&0&38
Driver: C:\WINNT\system32\DRIVERS\isapnp.sys, 5.00.2195.6655
(English), 6/19/2003 14:05:04, 46992 bytes
Name: CNet PRO200WL PCI Fast Ethernet Adapter
Device ID: PCI\VEN_1282&DEV_9102&SUBSYS_434E4554&REV_31\2&EBB567F&0&78
Driver: C:\WINNT\system32\DRIVERS\DM9PCI5.SYS, 1.25.0001.0725
(English), 7/25/2001 15:49:54, 33207 bytes
Driver: C:\WINNT\system32\DM9Inst.DLL, 1.03.1009.2000 (English),
11/16/2000 16:35:46, 16424 bytes
Name: Creative AudioPCI (ES1371,ES1373) (WDM)
Device ID: PCI\VEN_1274&DEV_1371&SUBSYS_57538086&REV_04\2&EBB567F&0&60
Driver: C:\WINNT\system32\drivers\portcls.sys, 5.00.2195.6655
(English), 6/19/2003 14:05:04, 148208 bytes
Driver: C:\WINNT\system32\drivers\stream.sys, 5.03.0001.0904
(English), 7/9/2004 04:27:28, 48512 bytes
Driver: C:\WINNT\system32\wdmaud.drv, 5.00.2195.6673 (English),
Driver: C:\WINNT\system32\drivers\es1371mp.sys, 5.00.2174.0001
(English), 11/6/1999 05:11:56, 44528 bytes
Driver: C:\WINNT\system32\ksuser.dll, 5.03.0000.0900 (English),
Name: NVIDIA GeForce FX 5200
Device ID:
PCI\VEN_10DE&DEV_0322&SUBSYS_93091462&REV_A1\3&225B1D41&0&0008
Driver: C:\WINNT\system32\DRIVERS\nv4_mini.sys, 6.14.0010.6693
(English), 10/29/2004 16:50:00, 2826944 bytes
Driver: C:\WINNT\system32\nvsvc32.exe, 6.14.0010.6693 (English),
10/29/2004 16:50:00, 127043 bytes
Driver: C:\WINNT\system32\nvcod.dll, 1.00.0000.0015 (English),
10/29/2004 16:50:00, 32256 bytes
Driver: C:\WINNT\system32\nvcodins.dll, 1.00.0000.0015 (English),
Driver: C:\WINNT\system32\nv4_disp.dll, 6.14.0010.6693 (English),
Driver: C:\WINNT\system32\nvoglnt.dll, 6.14.0010.6693 (English),
10/29/2004 16:50:00, 5271552 bytes
Driver: C:\WINNT\system32\nvcpl.dll, 6.14.0010.6693 (English),
10/29/2004 16:50:00, 4620288 bytes
Driver: C:\WINNT\system32\nvmctray.dll, 6.14.0010.6693 (English),
10/29/2004 16:50:00, 86016 bytes
Driver: C:\WINNT\system32\nvwddi.dll, 6.14.0010.6693 (English),
10/29/2004 16:50:00, 81920 bytes
Driver: C:\WINNT\system32\nvnt4cpl.dll, 6.14.0010.6693 (English),
10/29/2004 16:50:00, 245760 bytes
Driver: C:\WINNT\help\nvcpl.hlp, 10/29/2004 16:50:00, 161839 bytes
Driver: C:\WINNT\help\nvwcplen.hlp, 10/29/2004 16:50:00, 55256
bytes
DirectX Components
ddraw.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
265728 bytes
ddrawex.dll: 5.00.2134.0001 English Final Retail 7/26/2000 07:00:00
24336 bytes
dxapi.sys: 5.00.2180.0001 English Final Retail 7/26/2000 07:00:00
10064 bytes
d3d8.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
1179648 bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
7168 bytes
d3d9.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
1689600 bytes
d3dim.dll: 5.00.2180.0001 English Final Retail 12/12/2002 00:14:32
446224 bytes
d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02
797184 bytes
d3dref.dll: 5.00.2180.0001 English Final Retail 7/26/2000 07:00:00
93456 bytes
d3dramp.dll: 5.00.2180.0001 English Final Retail 12/12/2002 00:14:32
591120 bytes
d3drm.dll: 5.00.2134.0001 English Final Retail 12/12/2002 00:14:32
364816 bytes
d3dxof.dll: 5.00.2135.0001 English Final Retail 12/12/2002 00:14:32
49424 bytes
d3dpmesh.dll: 5.00.2134.0001 English Final Retail 12/12/2002 00:14:32
37648 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 7/26/2000 07:00:00
33040 bytes
dplayx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
230400 bytes
dpmodemx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
22016 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 7/26/2000 07:00:00
42768 bytes
dpwsockx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
57856 bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
28160 bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
16896 bytes
dpnet.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
377856 bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
3072 bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
3072 bytes
dpvoice.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
203264 bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
80896 bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
112128 bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
19968 bytes
dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02
32768 bytes
dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02
68096 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 7/26/2000 07:00:00
53520 bytes
dinput.dll: 5.01.2600.0881 English Final Retail 10/30/2001 08:10:00
150016 bytes
dinput8.dll: 5.01.2600.0881 English Final Retail 10/30/2001 08:10:00
166400 bytes
dimap.dll: 5.01.2600.0881 English Final Retail 10/30/2001 08:10:00
44032 bytes
diactfrm.dll: 5.01.2600.0881 English Final Retail 10/30/2001 08:10:00
386048 bytes
joy.cpl: 5.01.2600.0881 English Final Retail 10/30/2001 08:10:00
326144 bytes
gcdef.dll: 5.01.2600.0881 English Final Retail 10/30/2001 08:10:00
206336 bytes
pid.dll: 5.01.2600.0881 English Final Retail 10/30/2001 08:10:00
31744 bytes
gameenum.sys: 5.00.2195.6655 English Final Retail 6/19/2003 14:05:04
9808 bytes
dsound.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
363520 bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
18432 bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
186880 bytes
dsdmoprp.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
68096 bytes
dmusic.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
104448 bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
27136 bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
58368 bytes
dmime.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
181248 bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
33280 bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
98816 bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
100864 bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
76800 bytes
system.dll: 1.01.4322.2032 English Final Retail 9/15/2004 15:32:19
1224704 bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
602624 bytes
dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02
1189888 bytes
dxdiagn.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
1769472 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 7/26/2000 07:00:00
924432 bytes
mfc42.dll: 6.00.9586.0000 English Beta Retail 6/19/2003 14:05:04
1015859 bytes
wsock32.dll: 5.00.2195.6603 English Final Retail 6/19/2003 14:05:04
21776 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
64512 bytes
devenum.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02
53248 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 6/19/2003 14:05:04
498205 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
136192 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
13312 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
18944 bytes
qasf.dll: 9.00.0000.2980 English Final Retail 12/11/2002 16:34:40
241664 bytes
qcap.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
177152 bytes
qdv.dll: 6.05.0001.0904 English Final Retail 7/9/2004 04:27:28
276480 bytes
qdvd.dll: 6.05.0001.0904 English Final Retail 7/9/2004 04:27:28
382976 bytes
qedit.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
524800 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
733184 bytes
quartz.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02
1136640 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 6/19/2003 14:05:04
246544 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 7/26/2000 07:00:00
199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 7/26/2000 07:00:00
848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 7/26/2000 07:00:00
120320 bytes
ir41_qcx.dll: 0.00.0000.0000 English Final Retail 7/26/2000 07:00:00
338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 7/26/2000 07:00:00
755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 7/26/2000 07:00:00
200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 7/26/2000 07:00:00
183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 7/26/2000 07:00:00
154624 bytes
mswebdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32
194560 bytes
ks.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
130304 bytes
ksproxy.ax: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
117248 bytes
ksuser.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
4096 bytes
stream.sys: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28
48512 bytes
mspclock.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
5248 bytes
mspqm.sys: 5.00.2134.0001 English Final Retail 9/25/1999 05:36:32
4816 bytes
mskssrv.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
7424 bytes
swenum.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
4096 bytes
mstee.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32
5504 bytes
bdaplgin.ax: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:04
16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:04
11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 7/9/2004 02:58:18
52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 7/9/2004 02:58:34
354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 7/9/2004 02:58:36
30208 bytes
ipsink.ax: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:06
14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 7/9/2004 02:58:12
57856 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:30
10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:10
15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:40
14976 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 7/9/2004 02:58:08
480256 bytes
slip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:38
10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:28
83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:06
16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:40
27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:26
16896 bytes
kstvtune.ax: 5.03.0001.0904 English Final Retail 7/19/2004 16:19:30
285696 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 7/9/2004 02:58:10
39424 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:26
226304 bytes
vfwwdm32.dll: 5.00.2195.6655 English Final Retail 6/19/2003 15:05:04
51472 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:44
18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:48
47104 bytes
msdv.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:14
56832 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.0000.0900
CC Decoder,0x00200000,2,1,,5.03.0000.0900
WST Codec,0x00200000,1,1,,5.03.0000.0900
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
WMVideo 8 Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
RTP Source Filter,0x00200000,0,1,dxmrtp.dll,5.00.2195.6611
RTP Render Filter,0x00200000,1,0,dxmrtp.dll,5.00.2195.6611
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.0001.0902
DV Muxer,0x00400000,0,0,qdv.dll,6.05.0001.0904
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.0001.0902
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.2980
Intel RTP SPH for
G.711/G.723.1,0x00200000,1,1,dxmrtp.dll,5.00.2195.6611
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.0001.0902
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Compression
Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,7.00.0000.1954
PCM Silence Suppressor,0x00200000,1,1,dxmrtp.dll,5.00.2195.6611
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Decompression
Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
H261 Decode Filter,0x00200000,1,1,h261_32.ax,5.00.2195.6611
Microsoft Screen Video
Decompressor,0x00800000,1,1,msscds32.ax,7.01.0000.3055
H263 Decode Filter,0x00200000,1,1,h263_32.ax,5.00.2195.6611
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.0001.0902
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Intel RTP Demux Filter,0x00200000,1,1,dxmrtp.dll,5.00.2195.6611
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.0001.0900
Intel RTP SPH for Generic
Audio,0x00200000,1,1,dxmrtp.dll,5.00.2195.6611
ACELP.net Sipro Lab Audio
Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command
Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.0001.0902
File Source (Netshow URL),0x00400000,0,1,dxmasf.dll,6.04.0009.1125
DV Splitter,0x00600000,1,2,qdv.dll,6.05.0001.0904
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,7.01.0000.3055
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.0001.0902
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.0371
Windows Media Multiplexer,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASX file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASX v.2 file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1125
NSC file Parser,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.0001.0902
Windows Media source filter,0x00600000,0,2,dxmasf.dll,6.04.0009.1125
Video Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.0001.0904
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.0001.0902
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.0000.0900
Video Renderer,0x00800000,1,0,quartz.dll,6.05.0001.0902
Microsoft MPEG-4 Video
Decompressor,0x00800000,1,1,mp4sds32.ax,8.00.0000.0344
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.2980
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.0000.0900
Decompressor,0x00800000,1,1,mpg4ds32.ax,7.01.0000.3055
File writer,0x00200000,1,0,qcap.dll,6.05.0001.0900
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.0001.0904
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.0001.0904
Cutlist File Source,0x00200000,0,1,qcut.dll,6.01.0009.0726
AVI Draw,0x00600064,9,1,quartz.dll,6.05.0001.0902
..RAM file Parser,0x00600000,1,0,dxmasf.dll,6.04.0009.1125
G.711 Codec,0x00200000,1,1,g711codc.ax,5.00.2143.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.0001.0904
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,dxmasf.dll,6.04.0009.1125
ASF DIB Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASF ACM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASF ICM Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASF URL Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASF JPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASF DJPEG Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
ASF embedded stuff Handler,0x00600000,1,1,dxmasf.dll,6.04.0009.1125
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.0001.0900
Null Renderer,0x00200000,1,0,qedit.dll,6.05.0001.0900
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.0001.0900
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
H263 Encode Filter,0x00200000,1,1,h263_32.ax,5.00.2195.6611
Smart Tee,0x00200000,1,2,qcap.dll,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.0001.0904
Microsoft PCM Audio Mixer,0x00200000,1,1,dxmrtp.dll,5.00.2195.6611
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.0933
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.0001.0902
Intel RTP RPH for
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.0001.0902
Wave Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
File stream renderer,0x00400000,1,1,quartz.dll,6.05.0001.0902
XML Playlist,0x00400000,1,0,dxmasf.dll,6.04.0009.1125
AVI Mux,0x00200000,1,0,qcap.dll,6.05.0001.0900
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.0001.0902
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.0001.0902
File Source (URL),0x00400000,0,1,quartz.dll,6.05.0001.0902
Intel RTP SPH for H.263/H.261,0x00200000,1,1,dxmrtp.dll,5.00.2195.6611
Intel RTP RPH for H.263/H.261,0x00200000,1,1,dxmrtp.dll,5.00.2195.6611
Intel RTP RPH for Generic
H261 Encode Filter,0x00200000,1,1,h261_32.ax,5.00.2195.6611
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.0001.0900
BDA MPEG2 Transport Information
Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.0001.0902
Indeo® video 4.4 Decompression
Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression
Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.0000.0900
WDM Streaming Data Transforms:
Microsoft Kernel GS Wavetable
Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft DirectMusic SW Synth (WDM),0x00200000,1,1,,5.03.0000.0900
Video Compressors:
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.0001.0904
Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.0001.0902
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.0001.0900
{D76E2820-1563-11CF-AC98-00AA004C0FA9},0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.0001.0900
Toshiba YUV Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.0001.0902
Lernout & Hauspie CELP
4.8kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
12kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
16kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
ACELP.net,0x00200000,1,1,quartz.dll,6.05.0001.0902
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.0001.0902
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.0001.0902
Audio Capture Sources:
Creative Sound Blaster PCI,0x00200000,0,0,qcap.dll,6.05.0001.0900
Midi Renderers:
Creative Sound Blaster PCI,0x00200000,1,0,quartz.dll,6.05.0001.0902
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Synth,0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming Capture Devices:
Creative Sound Blaster PCI,0x00200000,2,2,,5.03.0000.0900
Raw Channel Access Capture/Render,0x00200000,1,1,,5.03.0000.0900
WDM Streaming Rendering Devices:
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.0000.0900
BDA Network Providers:
Microsoft ATSC Network
Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network
Microsoft DVBS Network
Microsoft DVBT Network
BDA Transport Information Renderers:
Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.0001.0900
WDM Streaming Mixer Devices:
Microsoft Kernel Audio Mixer,0x00200000,2,2,,5.03.0000.0900
WDM Streaming Communication Transforms:
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.0001.0902
DirectSound: Creative Sound Blaster
WDM Streaming System Devices:
Creative Sound Blaster PCI,0x00200000,9,2,,5.03.0000.0900
BDA Receiver Component:
BDA Slip De-Framer,0x00600000,1,1,,5.03.0000.0900
BDA MPE Filter,0x00600000,1,1,,5.03.0000.0900
I would also get this message in the error log:
Anyu ideas?
Thanks,
Mark Ferrante
On Tue, 14 Dec 2004 07:19:41 GMT, "Nerdillius Maximus"
>snip
>Read, please...
>ok?
>PCI slot...
G
Guest
Guest
Pete D:
>> Ferrante:
>>> I found ... two items on the same IRQ channel. Could that be the
>>> problem?
>> sound card and video card on the same IRQ could cause problems...
> or WinXP you could have 4 on the same IRQ.
We are both guilty of making assumptions... I assumed he would be
running 95/98 on a machine that old and you assumed he would be running
XP on an old machine. If he is running 95/98, which is a reasonable
assumption IMO, then yes, it does matter.
http://www.google.com/search?hl=en&q=windows+95+IRQ+conflicts&btnG=Googl
e+Search
Hope this helps.
Mac Cool
G
Guest
Guest
Ferrante:
Now quit beating around the bush and tell us what game you trying to play.
Are you having issues with other games or software?
Mac Cool
DaveL
634
Move the sound card. Try to get it onto IRQ5. I don't think the error
loading WDM is the problem. It's just a leftover ATI capture. You can
download a driver cleaner from ATI's website.
DaveL
> > Ferrante:
> >> [IRQs]
> >> IRQ Number Device
the
> > Mac Cool
G
Guest
Guest
On Wed, 15 Dec 2004 09:12:40 -0800, "DaveL" <dave1027@comcast.net>
I've done that already with the ATI cleaner. I will try to move the
sound card.
Mark
>DaveL
>> > Ferrante:
>> >> [IRQs]
>> >> IRQ Number Device
>the
>> > Mac Cool
DaveL
634
Something just accured to me. Is your motherboard an LX chipset? If so,
could be the agp slot can't supply enough current to run the video card. It
was a common problem back in that day.
DaveL
"Ferrante" <manthonyferrante@yahoo.com> wrote in message
news:0vu0s0pgmh1l4hn3kcc1fotnbss2s2fjso@4ax.com...
> sound card.
> Mark
> >DaveL
> >> > Ferrante:
called
> >> >> [IRQs]
> >> >> IRQ Number Device
sound
> >the
slot
> >> > Mac Cool
G
Guest
Guest
On Wed, 15 Dec 2004 03:54:33 GMT, Mac Cool <Mac@2cool.com> wrote:
>Ferrante:
The game is JFK Reloaded (www,jfkreloaded.com). I seem to meet all the
minimum requirements and some of the recommended ones. It is just with
this game, however, now on my Isnooker game, when the game comes up,
the pool table is now absent even though everything else is there.
I've tried reinstalling and all that and nothing.
I'm having a bad hair week(s).
Mark
G
Guest
Guest
On Wed, 15 Dec 2004 10:22:49 -0800, "DaveL" <dave1027@comcast.net>
LX? I don't know. Does this help:
Operating System System Model
Windows 2000 Professional Service Pack 4 (build 2195)
Gateway G6-400
System Serial Number: 00
Chassis Serial Number:
Processor a Main Circuit Board b
400 megahertz Intel Pentium II
32 kilobyte primary memory cache
512 kilobyte secondary memory cache Board: Intel
Corporation WS440BX AA719570-206
Serial Number: ISWS90401710
Bus Clock: 100 megahertz
BIOS: Intel Corp. 4W4SB0X0.15A.0006.P04 10/09/98
Here is what I have on my computer (From Gateway)
http://support.gateway.com/s/MOTHERBD/INTEL/m00402/m0040212.shtml
The guys at the computer store told me that they GeForce FX5200 I
bought would clock down to 2x, so they said my computer could handle
it. Also, the problem existed before I got this card. Then I had an
older Vodoo Banshee.
Your thoughts?
Mark
>DaveL
>> sound card.
>> Mark
>> >DaveL
>> >> > Ferrante:
>called
>> >> >> [IRQs]
>> >> >> IRQ Number Device
>sound
>> >the
>slot
>> >> > Mac Cool
DaveL
634
Well, Nerd Max is correct. The PII 400 is a 100 mhz fsb cpu, so you don't
have an LX chipset board. Most likely a BX chipset.
DaveL
news:92d1s0h68cqgp7061e0v2tnbcmjihh141b@4ax.com...
It
> Gateway G6-400
> Your thoughts?
> Mark
> >DaveL
error
can
> >> sound card.
> >> Mark
> >> >DaveL
> >> >> > Ferrante:
> >called
channel.
> >> >> >> [IRQs]
> >> >> >> IRQ Number Device
> >sound
have
> >> >the
> >slot
IRQ.
> >> >> > Mac Cool
or
G
Guest
Guest
On Wed, 15 Dec 2004 20:48:20 GMT, "Nerdillius Maximus"
>"DaveL" <dave1027@comcast.net> wrote in message
>news:vaadnaFOOIA8HV3cRVn-hg@comcast.com...
>It
>It's a Pentium 2 400 (4x100). And LX mobos only went up to 83 MHz FSB, max
>(and not always very reliably...). This means it's most likely a...
>Now after hearing which game it is, my help ends here.
I fully understand and I am sorry if I caused you distress. Thanks for
trying to help me.
Mark
