Problem Overclocking P4C 2.4GHz
  • Nvidia
  • Overclocking
  • Motherboards
  • Graphics
January 5, 2005 9:20:01 PM
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
I just bought a good cooling system so I can overclock my CPU. The
problem is that in my motherboard I don't see anything about
multiplier. Anyway I downloaded Easytune 4 and 5. With none of them I
can change the multiplier. It says that the multiplier is at 12 but I
can't increase it. Why is that? is that my motherboard that doesn't
support higher multiplier or is it my CPU that locks it. Oh yea well
any I increased the FSB but it also automaticly incrases the RAMs MHz
which is normally 333MHz. Whatever I don't want to overclock with the
FSB I'd like to just increase the multiplier so I'd like to know why I
can't.
System spec.
Mobo: Gigabyte GA-8IPE1000 Rev1.0
1 x 512DDR PC 2700 (333MHz)
Pentium 4 C 2.4GHz 800FSB 512KB
Heatsink: Zalman CNPS 7700-Cu
More about : problem overclocking p4c 4ghz
January 5, 2005 10:06:01 PM
What I mean't by saying that I don't see anything in my motherboard
well actually I don't see anything about multiplier in the bios.
Anonymous
a b K Overclocking
a b V Motherboard
January 6, 2005 6:56:11 AM
If you don't want to increase the FSB, you should have gotten an AMD. Intel
CPU's are all multiplier locked and the only way that you can o/c the chip
is through the FSB.
Silvertip
"John" <beretta92fs_inox@hotmail.com> wrote in message
news:1104978001.159206.297180@f14g2000cwb.googlegroups.com...
> can't.
> System spec.
January 6, 2005 1:12:25 PM
AMD processors (except for mobile and FX) are also multiplier locked since
about a year and a half ago.
DaveL
"Silvertip" <sparksr1@earthlink.net> wrote in message
news:vF2Dd.1563$Pm6.392@newsread1.news.pas.earthlink.net...
Intel
> is through the FSB.
> Silvertip
> > can't.
> > System spec.
Anonymous
a b K Overclocking
a b V Motherboard
January 6, 2005 5:32:44 PM
Instead of using a program to up the fsb i reckon that u should just do it
on the bios screen and see if it stix then.
January 6, 2005 6:39:02 PM
Does worth it there isnt risk if I get DDR400 or higher to raise the
FSB. But right now I bought to much things for gaming. 6600GT + Kick
Ass Cooling just don't have money for more that's why I wanted to
overclock but for now the il just have to put the cooling system away
for a bit. I even had to remove my case's top to put out the power
supply to make place for the heatsink lol... Oh well. Thanks for the
help
