Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Hi, new here and am looking for some solutions to my problem. My
system is as follows:
AMD Athlon 3500+
MSI K8N Neo4 Platinum mobo
2x512meg Corsair Twinx memory
Hitachi 120 gig HD SATA
MSI NX 6600GT 128meg PCI-E vid card (with no extra power supply
needed) funning nVidia 66.93 drivers.
XP Pro w/SP-2 and all the updates.
All equipment is new and just put together last Friday.
After installing the video drivers, I get colored squares all over the
monitor, and a rectangle grouping around the cursor. When trying to
change refresh rates to match the resolution I want, screen goes to
black
constantly till I restart. Then will usually freeze/lock-up system if
there is a site with pictures. Tried uninstalling everything,
reformatting and starting from scratch to no avail.
Without the drivers, and running just the basic XP drivers, sreen is
fine, although I did notice a few blue squares in images with a lot
of blacks.
Anyone have any idea what is wrong? This is the monitor I am using
http://www.kdscanada.ca/2003/Xflat/xf9bi.htm
Could my card be defective? Install something wrong?
Thanks for any ideas anyone might have to solve the problem.
MT
AMD Athlon 3500+
black
of blacks.
MT
